Old 10-11-2005, 04:30 PM   #1 (permalink)
My Photos: (5)
Send a message via ICQ to igotrobbed
Callipers?
I hear a rubbing noise from I think the drivers side tire . When i apply a small amount of brake pressure it goes away . When I brake my truck feels like its going over a ton of little bumps .
I just replaced all back brakes .
Any way to trouble shoot this further , or just buy new calipers?
1988 F-350 frame -- 90' E4od and 7.3 motor 130K -- 90'-95' Body paionted -- New Injection pump professionaly timed ,injector installation kit,Injectors - rear bearings in&out+seals - rear drive shaft /yoke-U-joints- controller/relay- glow plugs- drums- brake pads all around- power steering box- installed used fan clutch & blades- Installed used steering column with cruise - 2 new batteries- rear leaf springs- voltage regulator - Block heater/ pump(used)- used front tank (in perfect condition)- tranny cooling lines
02 Dodge cummins 4x4 longbed
igotrobbed is offline
Old 10-11-2005, 05:31 PM   #2 (permalink)
Re: Callipers?
Sounds like your experiencing brake chatter which is usually caused by the front rotors having checks or hardspots. It can also be caused by thin pads or rotors that are due for a turning.
The rubbing noise could be a caliper hanging up or not centering it's self over the rotor.
Pull the tire and look at the pads - If they are worn more inside or out then your caliper is not sliding properly over the rotor or the pistons are hanging up and letting the pad continue to drag after you release the brake pedal.
1996 F350 CrewCab XLT 4x4 zf5sp with 1996 5.9 Cummins Turbo Diesel
FordCummins1 is offline
Old 10-12-2005, 02:18 PM   #3 (permalink)
My Photos: (23)
Re: Callipers?
We assume from your post that your certain the noise and vibration are from the front brakes.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
