Re: Can i use a fuel sender out of a gasser???
thanks for the pix [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
i know there is no heater in the tank, but i thought they had a chamber where the returning fuel(from the I-pump) would mix with the incoming fuel, this is the setup the powerstroke has and it causes alot of air to enter the fuel system
after looking at the pix i guess the thing i was referring to was the fuel pick-up's bypass valve
2001 F-350 7.3L 4X4(ESOF) CC LWB 4R100 4X4, WIX 46637 open element air filter, Wicked Wheel, walker BTM, 203* Tstat, IC tube foil removed, coolant filter, AIH removed, 08 aluminum finned rear end cover, DP tuner 80econ 140smoke high idle,Phantom gauges, ATS transmission,ATS deep trans pan, 5 star torque converter, V10 trans cooler, 4" MRBP SS downpipe, twin 4" stacks
1989 F-250 6.9L IDI E4OD 500,000+ miles(sold)
1982 VW rabbit 1.6L diesel
