Re: Can someone measure their F450 front springs for me?
Needed to do some put off inspecting under there so thought I'd do it now and maybe help you in the process. The leaf springs measure 50¾" from center of bushing to center of bushing. The length from center of front bushing to center of front axle is 23¾". The springs are 2" thick at the axle and 3" wide. This is a 1988 chassis so not sure it would be the same as your '91.
'90 F-450 SD, 7.3L IDI DSL, ZF-5 spd manual, 2wd, 11" x 10 spline clutch, 2-wd, contractors 10' dump box, standard cab, bench seat, Dana 80 rear w/4.63:1 gears, 174" wheel base (need lotsa room to turn),weighs in at a little over 9000, no frills.
'96 F-250 PSD standard cab, 2wd, E4OD, 328K on the clock.
