Can you test the GP controller? - Diesel Forum - TheDieselStop.com
Old 11-07-2009, 06:07 PM   #1 (permalink)
rsr911's Avatar
Well I was replacing my batteries a few weeks back and I might have fried something. My controller had been working but the two heavy yellow wires (fusible links) had burned out so I put about a 5' battery cable in place temporarily and all was well in the world. That was until I replace the batteries, see that cable was running over the pass. side battery and I tugged on it a little to get the old battery out and put the new one in. I connect the terminals and I hear the key buzzer run but the keys weren't in it. Get it hooked up and start it no problem but it won't shut off, pull the doghouse and find that my battery cable terminal to the GP solenoid had touched the white wire when I tugged on it earlier. Well now the GP relay wouldn't click anymore so I put a new one on and still nothing. There are no blown fuses and everything else works but the GP's. I'm thinking I might have shorted out the GP controller but I don't know how to test it. Also I tried to use a jumper to the white terminal to ground like some do for the manual GP mod and still no click of the relay.
1986 F350 Crew Cab 2wd SRW. 1991 7.3 IDI, T-19 4spd Sterling 10.25 3.55, 12" HD clutch. A Banks waste gated turbo. 5" cut down Peterbilt stack. Midwest rebuilt IP turned up. AC Delco 6.5 GM 12V GP's, working great. Running W85 high performance zero-gel diesel! D60 front conversion, 4wd conversion, dually conversion, and steel flatbed conversion now underway. Man those frame rivets are a pain!
1966 Porsche 911. 1983 911 SC engine with modified Zenith carbs, headers, 911S brakes, custom fuel rails, MSD 6al box with timing computer, 1974 IROC body kit. 1850lbs, 200rwhp, total blast to drive.
rsr911 is offline
Old 11-07-2009, 09:54 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (109)
PM me your email addy and I will forward the test.....
Info sent this AM
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 11-08-2009, 03:06 PM   #3 (permalink)
Beazer's Avatar
i would also like this sent to me as well i have the same problem...nobull4x4@yahoo.com
Beazer is offline
Old 11-14-2009, 09:00 PM   #4 (permalink)
need help will you please pm me how to test the GP controller @ ccastillo010@stx.rr.com i have a 1993 F250 turbo 2wheel dr.Z5
1993 f250 7.3fact.turbo new clutch,new slave clutch cylinder,new caps o-rings,4 days on brakes stops on dime,that also park brake,new a/c ,2wld 1951chevy 5window 216 2nd owner drive daily
castillo is offline
Old 11-14-2009, 10:55 PM   #5 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Beazer I tried sending before and it was bounced back....... just sent it again
Old 11-15-2009, 11:52 AM   #6 (permalink)
Beazer's Avatar
cdnsarguy i got it thank you for the help...my controller is shot.
Beazer is offline
Old 11-15-2009, 04:04 PM   #7 (permalink)
May i also have this sent to me as well. coleandjeana@yahoo.com
1991 F350 extended cab 7.3na DRW 2wd zf5 4.10LS
and my new one...
1994 F350 crewcab 4x4 zf5 7.3IDI turbo (factory)
SRW 4.10's clean truck!
coletrain777 is offline
