Re: cant getthe bearing thingy mabober off !
If a little heat does not loosen it up enough to slide the inner ring off, you will beed a 3 jaw bearing puller (gear puller). You will need a piece if metal or something to put across the end of the hub so the puller has something to pull against. Avoid using hammers, etc directly on the race, as it is very easy to slip and damage the threads, etc on the hub.
Also, as was said before, if you can cut a slot, and crack it with a hammer and chisel in the slot, that will take the tension off real quick.
*ASE Master Certified, Medium & Heavy Trucks*
