Can't hear the turbo is that normal? - Diesel Forum - TheDieselStop.com
Old 07-06-2009, 11:01 PM   #1 (permalink)
I had a 2000 PS prior to this one and I could hear the turbo real well. I am not sure if this one is working without hearing it. Any way to tell for sure w/out a boost gauge? Are they all that quiet on IDI's?
1994 F250 4X4 w/ 7.3 factory Turbo IDI and a 5 speed, 340K and going good
Living in NW Montana
7bicks is offline   Reply With Quote Quick reply to this message
Old 07-07-2009, 12:03 AM   #2 (permalink)
typefour's Avatar
If it still has the stock exhaust it will be pretty quiet.
91 F350 crew cab 4x4 7.3 ats and intercooled with cut down 2000 ps cooler, bigger turbo comp,head studs, torque cam, coated rockers , balanced. very good power.
made 218hp/461tq on a mustang dyno lasst dec with 80k on the rebuild
pyro,boost and all stock guages ignored with mechanical real ones
Fugitive sandrail. type 4 2840 turbo fi, lots of fun
PM please not visitor message
typefour is offline   Reply With Quote Quick reply to this message
Old 07-07-2009, 11:12 AM   #3 (permalink)
BobG's Avatar
I couldn't hear mine either until I upgraded to the 3" down pipe and larger exhuast with a open muffler. Sounds nice now.
'94 F250 IDI 4X4 5 speed. New to me in '03. . "A" pillar gauges ATS Turbo upgrade 3" down pipe & exhaust, Baby Moose IP, "BB" injectors, coolant filter and PS intercooler.
1975 CJ5 AMC 360 Boxed frame, shackle reverse and sprung over, YJ springs, Twin stick D20 with D18 low range gears, NP435 Waggy axles 538 gears, on board air, welder and shower, GM throttle body injection
2004 Jaguar XJ8
2004 Heritage Softail
2009 Road King
BobG is offline   Reply With Quote Quick reply to this message
Old 07-07-2009, 12:28 PM   #4 (permalink)
Thanks for the information. I may go with the larger down pipe but hate to do too much as it has 338,000 miles.
Old 07-07-2009, 07:12 PM   #5 (permalink)
asauer's Avatar
Send a message via MSN to asauer Send a message via Skype™ to asauer
All IDIs sound pretty quiet compared to different motors. I guess it's because of the restrictive exhaust/low boost. I could hardly hear the turbo on my '94, didn't really notice on my '89 but I drove it a total of probably 50 miles at most with the turbo on it.
My 2000 Jetta puts them both to shame. It whistles pretty good with stock exhaust and the engine cover and plastic belly pan replaced with an aluminum skidplate.
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
Member of Indiana Air National Guard 122FW MXS
asauer is offline   Reply With Quote Quick reply to this message
Old 07-08-2009, 10:07 PM   #6 (permalink)
7.3L F-250's Avatar
My Photos: (16)
Send a message via AIM to 7.3L F-250
the thing is the noise of an idi is louder then that of a turbo even with my 4" exhaust
the powerstroke engines are quieter then the idis so you can hear the turbos easyer
company trucks
2002 ford F-350 powerstroke cc sb zf-6
1987 ford F-350 6.9L idi flat bed
1989 ford F-350 7.3L idi pick up
CURRENT PROJECTS
1978 ford F-350 custom
7.3L F-250 is offline   Reply With Quote Quick reply to this message
Old 07-09-2009, 08:21 PM   #7 (permalink)
I think its the fact that turbo idis only push about 10-15 psi boost, while strokers push over 25.
DieselTorque is offline   Reply With Quote Quick reply to this message
Old 07-09-2009, 09:02 PM   #8 (permalink)
chuckster57's Avatar
Mine has the bigger turbine housing and outlet with a 3" exhaust. I have not turned up the fuel and pulling the trailer with my foot into it on a hill @ 2600RPM I see @ 7 PSI of boost on the gauge. It was quiet when it had the stock smashed down pipe but I can clearly hear it now, not real loud but sweet none the less
Train Horns: Pictures here
chuckster57 is online now   Reply With Quote Quick reply to this message
Old 07-09-2009, 09:27 PM   #9 (permalink)
Bill1013's Avatar
Sure would like to get my stock stroker over 15.
Even with the muffler delete and SP Diesel Performance set to 80HP and hammer down, redlined, turbo screaming, black smoking to 90MPH it might have hit 17 boost,. And Oh, don't know where those Red and Blue flashing lights came from, nice Lady Cop, told her It's a Diesel, You Wouldn't Understand, just testing. Her remark was "Oh yes I do, got one too, now keep it down" Amen.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One Flash and it's gone forever.
Bill1013 is offline   Reply With Quote Quick reply to this message
Old 07-12-2009, 12:10 PM   #10 (permalink)
drinkypoo's Avatar
My Photos: (25)
I have an ATS 088 turbo. It pushes only 11 PSI (by gauge) max. This is the design maximum; it is wastegateless. This makes good sense because the compression on these engines is high even for a diesel (though not astronomically so, and still less than my Mercedes 300SD W126 617.951) Trying to push much more boost in the IDI would require build-up and in my inexpert opinion (mostly from what I've read since buying my truck) would probably be a better idea on the thicker-walled 6.9.
Turbos make diesels QUIETER on the exhaust side, and I couldn't hear my turbo until I made a custom intake and deleted that big stupid cast aluminum box with the ATS logo on it, which had no purpose other than to cause turbulence and increase heat in the valley.
1997 Audi A8 Quattro 225k Warm/Cold packages
Last edited by drinkypoo; 07-12-2009 at 05:02 PM. Reason: Want to add more I forgot
drinkypoo is offline   Reply With Quote Quick reply to this message
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
