Old 01-16-2007, 01:39 PM   #1 (permalink)
Cant move the shifter to 1st
E40D can't move the shifter past 2nd. Trans shifts fine I just cant manually move it to first any ideas. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1993 Ford F-250 Diesel 7.3L IDI, E40D Auto, 4x4, Super cab Long bed. Bone Stock with 254,000 miles on it. 2.5" lift from Tuff Country & Super Winch Lockout hubs
CBNASH is offline
Old 01-16-2007, 02:36 PM   #2 (permalink)
Re: Cant move the shifter to 1st
Linkage adjustment?
Fighting Texas Aggie 03
86 Ford Bronco rolling on 37's
92 F250(tow rig/daily driver)
fbronco86 is offline
Old 01-16-2007, 02:41 PM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Possibly..........
Automatic Transmission Shift Rod or Shift Cable Adjustment... C6 and E4OD
1 Raise vehicle on jack stands or hoist. (I'd block well and scramble under)
2 From inside the vehicle, place the select lever in D/C6 and OD/E4OD . Hang a three
pound weight on the selector lever ( six pack still full)
3 Remove shift cable from the transmission lever ball stud/shift rod.
4 Pull down the lock tab on the shift cable body.
5 Position transmission lever in drive position. This is three detents from the front-most
lever position with the first position counting as one.
6 Connect the cable and end fitting to the transmission lever ball stud/shift rod.
7 Push up on the lock tab to lock the cable in the correctly adjusted position or tighten nut
and bolt.
8 Remove jack stands and lower vehicle from hoist. Remove three pound weight from
column shift select lever.
9 After making adjustment, check for Park engagment. Check the transmission control lever
in all detent positions with the engine running to make sure correct detent/transmission
actions, readjust if necessary. Reset the PRNDL indicator as required.
CAUTION:
Under no circumstances will it be permissible to adjust the cable/shift rod in any position
other than D for C6 or OD for E4OD.
Now all should be ok if it is in PARK and everything works, remove blocks.
Road test...................(drink warm beer)
If you think it's just the cable, disconnect it at the MLPs and try it.
Proud Canadian BOOB man too!!
cdnsarguy is offline
