CDR valve - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 04-18-2006, 07:17 AM Thread Starter
CDR valve
Does anybody have a part number or a source for a CDR valve. Ford says it is out of production, and they no longer stock it. Thanks
"Mekka-lekka-hi, mekka-hiney-ho!"
Ggg6 is offline
post #2 of 14 (permalink) Old 04-18-2006, 07:34 AM
My Photos: (5)
Re: CDR valve
e3tz6a665a Ford CDR valve part number
1805319C1 International's part number
1991 Ford PL Custom Ambulance Type III 7.3L Diesel.
Pioneer AM/FM/XM/CD Stereo. Code 3 lightbar, Whelen Strobes and flasher lights. Whelen flood lights on front, rear and sides. There bright enough to turn darkness into daylight. Siren with several tones plus electronic airhorn and PA. Custom 3" exhaust from manifolds back with a
. Dual alternators and dual sets of batteries. If I need a jumpstart all I do is push a button. On spot tire chains that install and de-install themselves at the flip of a switch. Also has air compressor on board along with suction unit and O2 system.
1972 Cadillac Hightop Ambulance by Superior Lucky if I get 10MPG
CompuDoc is offline
post #3 of 14 (permalink) Old 04-18-2006, 08:03 AM
My Photos: (9)
Re: CDR valve
What is a CDR valve and what does it do? Do I have one on my 88 E350 7.3?
88 E350 7.3 C6 154k
done: Remanufactured Inj pump, New Stanadyne injectors, Michelin M/S tires, ShellZone AF & Fleetrite SCA, replaced and relocated fuel filter assembly, elec fuel pump, no flying saucer, return lines/ o-ring kit, new heater core, 8 Beru glow plugs, oil & filter, stabilator on sliding door (plastic slider cracked in half)
Hot compression readings:
2. 500 1. 500
4. 460 3. 420
6. 540 5. 465
8. 480 7. 540
to do: transmission fluid, fix rust spots, WVO conversion.........
nubiecanobie is offline
post #4 of 14 (permalink) Old 04-18-2006, 08:14 AM
cdnsarguy's Avatar
My Photos: (109)
Re: CDR valve
It's like a large PCV valve located behind the intake which ducts internal engine gasses to the intake for burning.
Visit my gallery I think there is a pic there still, do a search of my posts for CDR and there is lots of info.
Nwbie gotta hone your skills on the search feature.... [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #5 of 14 (permalink) Old 04-18-2006, 09:15 AM
My Photos: (9)
Re: CDR valve
I actually did do a search but did not find what CDR stands for. Besides, the 7.3 NA forum has so little traffic (compared to the Power Stroke forum) I thought I'd post more questions to re-invigorate it. [img]/ubbthreads/images/graemlins/ooo.gif[/img]
88 E350 7.3 C6 154k
2. 500 1. 500
4. 460 3. 420
6. 540 5. 465
8. 480 7. 540
post #6 of 14 (permalink) Old 04-18-2006, 09:32 AM
Re: CDR valve
CDR stands for Crankcase Depression Regulator.
'94 F250, 4X4, 7.3, E40D, 4.10, 147K
tim94f250 is offline
post #7 of 14 (permalink) Old 04-18-2006, 05:40 PM
Re: CDR valve
i went to the local ford dealer about a month ago and got a cdr valve. unless they have discontinued them within the last month they should be able to get one. good luck
1992 F250 7.3l 75,000
auto E4OD 4x4
regular cab
roberson_diesel is offline
post #8 of 14 (permalink) Old 04-18-2006, 10:01 PM
Re: CDR valve
It's not discontinued. It's just that Ford does not call it a "CDR". They call it some sort of adaptor.
It's an International part, just buy it there. The Ford part is just reboxed.
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
post #9 of 14 (permalink) Old 04-18-2006, 10:28 PM Thread Starter
Re: CDR valve
Thanks for the part numbers, I will try IH.
Can the CDR be eliminated?
I have come across another issue. Can 1990 IDI n/a heads be used on a 1994 IDI turbo engine? Ford is telling me no, but I do not trust all that Ford tells me. Thanks again.
Ggg6 is offline
post #10 of 14 (permalink) Old 04-19-2006, 01:24 AM
cdnsarguy's Avatar
My Photos: (109)
Re: CDR valve
Ford calls this item a "Adapter assembly for Crankcase Ventilation" Part number E3TZ-6A665-A
post #11 of 14 (permalink) Old 04-19-2006, 09:50 PM
My Photos: (10)
Re: CDR valve
just put a RDT on it. then ya have no worries
95 f-250 444e e4od 4X4 ex cab long bed 3.55ls White Knight Reverse Lights, AIC, FORD seatcovers, AFE STAGE2 INTAKE, 3" downpipe 4" exhuast, EDGE Evolution 100hp setting, auto meter ultra lite pyro, tranny and boost gauges, .177bb in FPR, amsoil atf in transmission & tcase, amsoil syn gear lube in rear diff, bilstien shocks, fog lights, 1000cca batteries
************future mods*******************
intercooler, smaller turbo housing, window tinting
03 vw jetta tdi stock for now
traxmedic is offline
post #12 of 14 (permalink) Old 04-19-2006, 10:46 PM Thread Starter
Re: CDR valve
RDT ?? You mean a draft tube.
What about the heads?
Ggg6 is offline
post #13 of 14 (permalink) Old 04-19-2006, 10:53 PM
typefour's Avatar
Re: CDR valve
The turbo heads have inconel exhaust valves. The non turbo are just ss alloy, I put new turbo valves in mine but have seen many non that ran for a long time, heat is the culprit.
91 F350 crew cab 4x4 7.3 ats and intercooled with cut down 2000 ps cooler, bigger turbo comp,head studs, torque cam, coated rockers , balanced. very good power.
made 218hp/461tq on a mustang dyno lasst dec with 80k on the rebuild
pyro,boost and all stock guages ignored with mechanical real ones
Fugitive sandrail. type 4 2840 turbo fi, lots of fun
PM please not visitor message
typefour is offline
post #14 of 14 (permalink) Old 04-20-2006, 06:44 AM Thread Starter
Re: CDR valve
So if I install the inconel exh valves in the IDI n/a heads they will work just fine.
Ggg6 is offline
