Old 03-21-2005, 06:02 PM   #1 (permalink)
My Photos: (14)
CDR Valve
I've search the board, but too many links to sift through. Anyone have a part number on this bad boy?
Old 71 '93,F350 Crewcab, 7.3IDI with Hypermax non-Wastegated Turbo, 5 Speed, 4" Fabtech Lift, Filter Engineering Coolant Filter, 4" Straight pipe.
TurboYT is offline
Old 03-21-2005, 06:20 PM   #2 (permalink)
Re: CDR Valve
I got mine from an IHC parts dealer using #1805319C1. CDNARSGUY has a diagram and some instructions in his gallery. Check it out, it helped me.
94 F350 Crew-Cab Dually 7.3L IDI, Non-Turbo {I Know the Accessory drives are 94, but still not positive that the engine is} (220K on the truck) (140K on the engine), E4OD... 79 CJ-7 running but not perfect... 66 IHC pick-up far from ready for prime-time.
My3sonsIHCandme is offline
Old 03-21-2005, 06:23 PM   #3 (permalink)
Re: CDR Valve
y dont u just make a RDT?
my photos
95 f-250 444e e4od 4X4 ex cab long bed 3.55ls White Knight Reverse Lights, AIC, FORD seatcovers, AFE STAGE2 INTAKE, 3" downpipe 4" exhuast, EDGE Evolution 100hp setting, auto meter ultra lite pyro, tranny and boost gauges, .177bb in FPR, amsoil atf in transmission & tcase, amsoil syn gear lube in rear diff, bilstien shocks, fog lights
************future mods************************
intercooler, smaller turbo housing, window tinting
85 vw golf 1.6L stock
traxmedic is offline
Old 03-21-2005, 08:10 PM   #4 (permalink)
wls
Re: CDR Valve
Is going thru the international, cheaper. Anyone have the ford pt #
1997 F-250, w/d-60 installed. Stock, all but straight exhaust/open air
wls is offline
Old 03-21-2005, 08:30 PM   #5 (permalink)
Re: CDR Valve
Sorry to hi-jack your thread Turbo, I need to replace mine as well. I called my local Ford stealership today they said "I never heard of that. Maybe you should call International." So I called the local Int. dealer and they said they can't find a number and to call Ford! I know I've seen a post on here a while back but I can't find it either. Are they (cdr's) all the same on the 7.3's? If so I will use the part number provided in this thread.
Jason
92' F-250 4x4, 7.3IDI-NA/Jasper E40D., 4.10's
K&N air filter(no soup bowl), 3 1/2" single exhaust, DPS tuned pump, new injectors, 305/70/16's on 16x10 chrome mods w/no lift.
Stickhauler is offline
Old 03-21-2005, 09:27 PM   #6 (permalink)
Re: CDR Valve
I am looking at my new one from Ford right now. E3TZ-6A665-A The reason the people looked at you like you were drunk is because they don't deal with diesels much. The mainly auto related ford dealer in Oklahoma City didn't believe me until I showed him the CDR on the truck. What I didn't know was that it was relocated when the PO installed the ATS turbo kit. It originally was under and infront of where the air goes into the intake manifold. The original air cleaner hide most of it from view. I believe if your guy looked at the emissions page he would have found it.
ATS told you to punch a hole in your valve cover and gave you a tube to attach to your CDR Valve Assembly. Another member of this forum, I believe, actually purchased a new valve cover when he dumped the CDR for a road draft. I think eventually I will go the road draft tube also. The better solution would have been for ATS to make a metal tube that would have fit in the original hole in the intake manifold that then ran towards the relocated CDR valve and then was attached by a short piece of hose.
AFter I install it I will let you know if my oil mess kinda settles down a bit. Right now it is not pretty.
Bob E.
93 F-250 4x4, EOD4, Optima Red Tops(group 34/78), ATS turbo mod, custom grill guard, custom headache rack and bed rails.
safetybob is offline
Old 03-21-2005, 09:43 PM   #7 (permalink)
Re: CDR Valve
Anyone have a part number for the little rubber grommet on top of the valve cover that the CDR/RDT plug into???
89 C-350 Centurion 4X4 (F-350 4door Bronco), W/93 7.3L IDI non-turbo, ZF 5-Speed(LUK)/BW 1356/Dana 60/Sterling 10.25, 3.55, Hypermax Turbo/Intercooler, 3 1/2" Exhaust/Pyro(inop), RDT, 265/75R16 BFG/AT on 16X8 American Racing Wheels 130,000 and still going strong
ColLonewolf is offline
Old 03-21-2005, 09:43 PM   #8 (permalink)
Re: CDR Valve
Thanks guys for the part numbers. I will call both dealerships in the morning to see who has the better price. Bob, did your new CDR come with the rubber grommets for the valley pan and intake or are they sold seperately?
Jason
Old 03-22-2005, 12:12 AM   #9 (permalink)
Re: CDR Valve
You need to give them the part number too. Yes it should be undewr emisson controls, taht's what it does. Ford nomenclature calls this thing a "crankcase ventilation adpater(from Agenem)" not a CDR valve.
J.D.'s Fords: 1986 F-250 6.9 diesel Solid State Glow Plug System 3.55 gears C-6 2WD 178,960 miles.... it still runs pretty good!
Wishlist H-max turbo, T19 tranny,
1989 Ford Ranger ga$$er, non runner, soon to be donated or scrapped!
jdkline is offline
Old 03-22-2005, 12:42 AM   #10 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: CDR Valve
Stickhauler........
Crankcase Depression Regulator-valley pan or valve cover grommet
E3TZ-6A892-A
CDR tube and grommet assembly
E8TZ-6A892-A
Need more parts info vusut the Dieselmann
http://www.intellidog.com/dieselmann/idiparts.htm
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 03-22-2005, 01:31 AM   #11 (permalink)
Re: CDR Valve
Here are the forum links that i have saved for a CDR.
CDR thread 1
CDR thread 2
CDR thread 3
Tyler
89 F-250HD 7.3L XLT Lariat 4x4, 5spd, 4.10 rear - ~200,000 miles
Best mpg - 17.5 (drafting behind a semi doing 65)
My Truck Pics
fsSnowboard is offline
Old 03-22-2005, 12:56 PM   #12 (permalink)
My Photos: (14)
Re: CDR Valve
ATS uses the hole in the intake manifold (where the CDR used to be) to drain the turbo oil back to the engine. Hypermax is the same way.
TurboYT is offline
Old 03-22-2005, 01:00 PM   #13 (permalink)
My Photos: (14)
Re: CDR Valve
I could also just use a "breather" correct? Don't really need to run anything back to the intake if I don't want?
TurboYT is offline
Old 03-22-2005, 02:59 PM   #14 (permalink)
Re: CDR Valve
Yea, I found out the hard way that the dealer parts guy has no idea what the CDR is. Took about 10 minutes looking at various diagrams on the computer to find the part.
Mine looked to be original with 245K on it. The valve and the intake were pretty oiled up.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 03-22-2005, 10:17 PM   #15 (permalink)
Re: CDR Valve
No grommets came with the valve. Also, don't be surprised if you cannot get the grommet. I tried to order one, my Ford guy said it was no longer available, and the tube was discontinued also.
Let us know what you find out.
Bob E.
