Old 08-01-2006, 12:18 PM   #1 (permalink)
Changing motor mounts
Hi guys,
I'm about 65 miles away from my truck & manuals. it appears that the driver's side motor mount is broken, I followed advice from awhile ago & finally got somebody to look at motor in gear while I gave it some throttle & the driver's side appeared to raise [img]/ubbthreads/images/graemlins/bleh.gif[/img]. So does someone know of a 'safe' point to jack on the engine to lift it enough to replace both motor mounts; or do I need to lift the motor with a cherry picker/engine hoist and do I need to loosen the E40D trans mounts to accomplish this.
I have a very short time to accomplish this this weekend, as my wife is still in the hospital parts will arrive probably today I won't be able to pick them up until Saturday morning.
Thanks, jerry
'91 F350 CC,7.3NA w/K&N,E40D(rebuilt--way too many times), 2WD,3.55 rear end,new IP,new u-joints & carrier bearing, new rotors, new calipers, new drums & hdware, added Auburn limited slip unit (2/8/05)w/valvoline synth 80-90w, new batt.cables,new window motors,new radiator & hoses, 500K, (new injectors)+ mi (now 678K miles)& still Truck'n. If I can fix it, it ain't broke, I'd rather do it myself.(yes, I add,stanadyne, lucas or power sytems fuel additive in every tank, w/maybe 1-2x year full big bottle dose split between both tanks). New tires & pretty wheels, front end rebuild 3/17/05. Bilsteins added 6/12/05. New motor mounts & valve cover gaskets (9/06.)Future hopes finally fixing my electric door locks & adding remote entry/alarm system.
http://community.webshots.com/user/jl_mendoza
jlmendoza is offline
Old 08-01-2006, 01:45 PM   #2 (permalink)
Re: Changing motor mounts
You can safely jack under the oil pan. Use wood between the oil pan and jack head so the contact against the pan is smooth.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 08-01-2006, 01:49 PM   #3 (permalink)
cdnsarguy's Avatar
My Photos: (66)
I have sent an email with info......re lifting engine for pan removal, this would enable your mount removal too I think.
Any one with first hand knowledge of how too, please post it for Jerry ASAP
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 08-01-2006, 05:16 PM   #4 (permalink)
I did mine with a jack, I placed a 2X4 on the pan lip and lifted it one side at a time I was not comfortable just pressing on the pan. The turbo side was tight, Had to push the turbo hard against the firewall, bit I did get it.
Good luck.
1990 F-350 Dually 4X4 CC Rebuilt Turbo and NEW 7.3L DAS engine, rebuilt rear diff, Reman E4OD Stage 1 injectors Stage 1 pump Baumann recal kit and TDC for E4OD dead trans again...
2004 F-350 4X4 CC 6.0 PSD
2004 Wilderness 320dbhs TT
DSBlack is offline
Old 08-01-2006, 06:37 PM   #5 (permalink)
Thanks everyone for your responses, I think I will try the jack & 2x4 method on each side of the oil pan. Hopefully that will git'r'done in short order without too much brain damage.
Doing it that way how long did it take you? (dsblack)
jerry
Old 08-02-2006, 06:50 PM   #6 (permalink)
About 4 hr if I remember right, Your's is NA so it may go quicker. I had a fight on the turbo side beacause the engine did not go as high.
Should no be too bad.
Good luck, and be careful
DSBlack is offline
