Changing Water Pump - Diesel Forum - TheDieselStop.com
Old 02-14-2010, 08:52 PM   #1 (permalink)
Changing Water Pump
My weep hole has been dumping coolant like it's 10 beers deep. So, I'll be changing my water pump after a coolant flush tomorrow... Please post any tips or advice below. I've got a new water pump, gasket, thermostat, hoses, belts....and anything I can think of that should be changed out while I have most of the accessories out.
Is there anything I should look out for? Any additional components that I should change out while I have everything torn apart?
Thanks for the help!
-Jason
1990 F-250 7.3L IDI 4x4
jshesbol is offline
Old 02-14-2010, 08:59 PM   #2 (permalink)
chuckster57's Avatar
Welcome to the Diesel Stop
The specified/required thermostat does not contain an internal bypass, since the bypass is located in the cylinder block. Whenever the thermostat is replaced, it is mandatory that only Motorcraft E5TZ-8575-C or Navistar 1807974C94 thermostat be installed.
Also be sure to add precharged coolant or else the required amount of SCA's. Distilled water also as tap water contains minerals that make the SCA's not work.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now
Old 02-14-2010, 09:03 PM   #3 (permalink)
so, is there a coolant that is a simple "pour in"? Otherwise, an additive? I'm sure that I can search for it, but a little extra info would be great. Starting the removal/replacement tomorrow morning. Thanks again!
-Jason
jshesbol is offline
Old 02-14-2010, 09:07 PM   #4 (permalink)
I use "FLEET CHARGE" as it has SCA's in it. It says that distilled water is not madatory but I do. I get it at tractor supply but if you google it, it is available from some auto parts stores.
Old 02-14-2010, 09:07 PM   #5 (permalink)
Plywood's Avatar
My Photos: (13)
Be aware, it should be in the instructions but a couple of the flanges on the water pump are thinner so if things aren't done right the bolts will go in deeper and hit the IP gear and ruin it.
If you want a pre-charged antifreeze you can get it at Napa. It's either Fleetcharge or Fleetguard but I think it's Fleetcharge.
Edit: Wow same minute as Chuckster, I think he's right though it is probable Tractor Supply on your side of the Rockies.
85 F250 XLT Lariat 4x4 7.3L N/A, C6, 315/75/16 Siped Wild Country Muds, Manual ZD9s, K&N, Soup Bowl Out, Dura-Lift Pump, Dynomax 3" Y-pipe-4" AFE Muffler-5" Turndown.
http://www.youtube.com/user/Theonlyplywood#p/u
Turn it up!
Plywood is offline
Old 02-14-2010, 09:11 PM   #6 (permalink)
Good point! I forgot that part.
Old 02-14-2010, 09:11 PM   #7 (permalink)
Alright, I'll be careful around the IP. Have not read the instructions yet....only gathered parts and materials. Thanks for the additional point to look for.
-Jason
jshesbol is offline
Old 02-14-2010, 10:44 PM   #8 (permalink)
catodd12's Avatar
I just recently replaced my radiator, while I had it torn apart I also replaced the water pump, thermostat, passenger side valve cover gasket, hoses and belts. I didn't like the cheezy water pump gasket that came with my FoMoCo water pump so I purchased a Felpro gasket from AutoZone and used Permatex Aviation #3 to seal it. Used Fleet Charge from Tractor Supply.
1992 F250 2wd 7.3 IDI E40D 3.55 gears 170,000
1996 F250 PSD CC SRW 4x4 5sp 250,000 mi
2001 F350 PSD CC SRW 4x4 6sp 110,000 mi
catodd12 is offline
Old 02-14-2010, 11:26 PM   #9 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Visit my photo link for all the R&R info........ specially with the 2 upper and 2 lower bolts. Ensure you use the correct torque setting or you will strip the front cover blind nuts.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 02-16-2010, 08:48 PM   #10 (permalink)
Thanks for all of the pointers, guys. Awesome info in the photo link as well. I've got the new pump in. Tomorrow, I'll re-install the accessories, fill with coolant and fire this thing up!
-Jason
jshesbol is offline
Old 02-17-2010, 10:15 PM   #11 (permalink)
Latest update. I've buttoned everything up, topped off the coolant and ran the truck for about 30 minutes. It never warmed up. So, the coolant isn't flowing. This is probably because even though I topped off the coolant, since it is trying to pump through the engine, there still isn't quite enough it there to promote flow. I'll let things cool off overnight, then top off, fill the overflow tank and try it again. I really hope that I didn't knock something loose that clogged the radiator or heater core.
-Jason
jshesbol is offline
Old 02-17-2010, 10:37 PM   #12 (permalink)
hose that comes off of the right side head--loosen it--till coolant comes out--then try the refill again--air lock--
94_turbo is offline
Old 02-18-2010, 06:56 PM   #13 (permalink)
Thanks for all the help! She's up and running with no further issues. You guys are awesome!
-Jason
jshesbol is offline
