Charging the batteries 88 F-250 non turbo - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 02-27-2008, 07:27 AM Thread Starter
Sushibob64's Avatar
Is it ok to leave all connections to and from both batteries when using a charger? And also,does it matter which one you start with if indeed it is ok to leave on the connections?
How about on my 92 F-250 non turbo?
Thanks, Robert
1988 F-250 7.3 IDI 4wd non turbo c6 auto crew cab. w/ 138,000
Blended DSE fuel in rear tank.Started 2-25-08 @ 132000 miles.Changed O-rings,rubber fuel lines,cleaned injectors,changed fuel and air filter.Changed Wiper motor 4-4-08.Cleaned injectors again 10-1-08 136000 miles.11-4-08-Changed all fuel line clamps and glow plugs(Wellman)
1988 F-250 7.3 IDI 2wd non turbo c6 auto crew cab w/ 92,000 miles.
Sushibob64 is offline
post #2 of 2 (permalink) Old 02-27-2008, 09:45 AM
asauer's Avatar
Send a message via MSN to asauer Send a message via Skype™ to asauer
There has been much debate about this a few months ago...
But no, it does not matter if you leave the connections on the batteries to charge them, and I also stand by my opinion (a few will disagree) that it does NOT matter which battery you hook the charger/jumper leads to, assuming you have heavy enough cables (factory size or larger). If you have the proper size cables running from one battery to the next, then on to the starter, the whole arguement of having to hook to the passenger's side battery is essentially a moot point. Copper cable is obviously a very good conductor with minimal line losses, therefore it is an insignificant difference as to which battery you hook to. Just use whichever is more handy for you.
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
Member of Indiana Air National Guard 122FW MXS
asauer is offline
Gear in this thread - Powered by O'Reilly Auto Parts
