charging issue - Diesel Forum - TheDieselStop.com
Old 10-17-2009, 10:16 PM   #1 (permalink)
Cjhstang's Avatar
charging issue
Well i think i'm down to replacing one of the last remaining components of my truck since i bought it four years ago...
The truck doesn't ever seem to wanna fully charge the batteries from the alternator...
The other day i replaced all gps, put the air filter hat back on touched the metal filter to the hot side of the gp solenoid as the hat seated to the intake, of course that kicked an impressive spark.
started the truck to test gps everything was great. truck sat for two days, temps dropped a little tried to fire her up and would turn over fast at all. batteries are new within two years, starter, terminals, wires, grounds all new.
i've had the batteries hooked up to a trickle charger over night for 12 hr intervals for the last three so i can get to and from work, but it still never fully charges (donno if 12 hours is long enough to charge 2 batteries on a trickel cell tho).
when i do drive when i get higher rpms i do get a higher voltage output. so i am getting something from the alt.
would that spark have fried the alternator?? the truck was off when it happened.
Bad regulator??
How do i test my alternator (at home) and what results would a good alternator yield?
7.3 IDI F-350 4x4 1990 150k miles
-Custom: '92 interior; '04 Hydroboost brake system; Volt/Temp/Oil Pressure/Oil temp/Trans temp/Boost/Pyro meters; Banks Sidewinder Turbo into 4" glasspack and dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump; Steering Box; Denso Starter
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-Dual 30micron to 2micron filter system... WMO WATF! Free Fuel!!
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
4.6l Mustang GT 1997 115K miles
GOTTA LOVE FORD MUSCLE
Cjhstang is offline
Old 10-17-2009, 10:27 PM   #2 (permalink)
Most parts shops will bench test altenators for free, at least around my neck of the woods they will. Also check the batteries separately. Disconnect both the batteries and check each one by itself. I had one bad battery discharging the other just like you had and if they weren't disconnected the bad battery would test as good.
Once I replaced the batteries I had no more problems for a year and a half then I ran into the same thing you are having. I never figured the problem out as I traded in my 99 on a 2010. Good luck.
gerryk is offline
Old 10-18-2009, 07:54 AM   #3 (permalink)
Snotzalot's Avatar
Charge both batteries, remove the ground from both batteries, check and record the voltage of both batteries, wait 24 hours and retest voltage, if there is a severe drop in one or both batteries you have bad/shorted batteries.
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger, 52,000 Miles
'90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak, Retired 11/8/2011 with blown trans.
7.3L Alternator Belt Idler Photos
Snotzalot is offline
Old 10-18-2009, 08:48 AM   #4 (permalink)
StrokerSmoker7.3's Avatar
If the alternator voltage output is fluctuating with the RPMs sounds like bad diodes in the alternator. I just replaced mine this week because of the same thing. One easy way to tell is, if you sit at a red light or stop sign at night with your headlights on, do they dim when you come to a stop and then get brighter when you give it throttle? If so, the the alternator has one or more bad diodes.
1989 F-250 4X4 C-6 7.3 IDI, 4.10 SRW, Cobra 148GTL, 4ft bed mounted whips, 12" Powerbass sub, 600W Powerbass amp, Sony Headunit, GPC override(thanks M.L.S.C), Factory Ford aluminum rims from OBS PSD, 4" exhaust, no soupbowl, B&M shift kit
1997 F-350 4X4 E4OD 7.3 Powerstroke, 3.55 SRW. 3"DP to 4" exhaust, TS performance 6pos. chip, Quadzilla Recon XGT, DIY Tymar style intake, Atwood fiberglass cap
StrokerSmoker7.3 is offline
Old 10-18-2009, 10:20 AM   #5 (permalink)
Cjhstang's Avatar
i know it sounds weird but i figured that was normal.. its done that since i bought the truck 4 years ago.
is there a way to test the alternator while its in the truck wo taking it to napa or the like?
-3" Body Lift
-8ft snow plow
Cjhstang is offline
Old 10-19-2009, 08:39 PM   #6 (permalink)
Snotzalot's Avatar
Inductive amp meter and test the voltage.
Regards,
Old 10-19-2009, 10:47 PM   #7 (permalink)
Kevin 007's Avatar
How about a bad voltage regulator? Im no expert, just throwing it out there.
1984 F-250 6.9, T-19, BW1345, D70 rear end. solid truck.
1984 toyota BJ60 Landcruiser, 3B diesel, H55f 5 speed, Best rig Ive ever owned. Never needs anything, 503,000km, Old Man Emu suspension, rusty and running strong Will certainly outlive all my other wheels
1985 Toyota 4wd pickup, single cab, rare 2lt 2.4l turbo diesel, 5 speed, custom flatdeck, timing belt every 100,000k and shes good to go. 393,000km Excellent fuel economy!
1983 Mercedes 300d, low mileage.....gorgeous!
Kevin 007 is offline
Old 10-19-2009, 11:08 PM   #8 (permalink)
Yeah go to an Advanced or the like and they should be able to hook it up to an inductive amp meter and test it in the truck. I was also thinking voltage regulator. I want to replace mine and see what happens. It's just the little silver box on the Pass. side fender right? How much do they normally run?
Old 10-20-2009, 05:02 AM   #9 (permalink)
Snotzalot's Avatar
What's the voltage at your batteries when the engine is running but all accessories etc off?
Regards,
Old 10-20-2009, 06:07 PM   #10 (permalink)
Somewhere between 11 and 14 volts I believe
Old 10-20-2009, 06:14 PM   #11 (permalink)
Snotzalot's Avatar
It should be a constant 13.8 volts when running.
Regards,
Old 10-20-2009, 10:19 PM   #12 (permalink)
Cjhstang's Avatar
how quickly should it rise to 13.8 after starting the truck? assuming non extreme temperatures.
-3" Body Lift
-8ft snow plow
Cjhstang is offline
Old 10-20-2009, 11:11 PM   #13 (permalink)
1987IDI's Avatar
My Photos: (14)
Even with extreme temps it should read 13 or 14 right away.
1987 F250 XLT Lariat
Regular Cab 2x4 6.9L 5-Speed
Homemade Propane Injection.
RUNS ON PURE WASTE MOTOR OIL!
No more diesel for me...
1987IDI is offline
Old 10-21-2009, 03:06 AM   #14 (permalink)
CGBear's Avatar
Mine's doing the same thing. It sounds like a bad battery. I have one brand new battery and one that just gave up the ghost. The bad battery pulls the new battery down overnight to the point that I have to throw the charger on it in the morning to get it going.
1993 F250 supercab longbed 4x4 with a quarter of a million miles. Stock 7.3, e40d trans and 3.55 rear gears. I got rid of my silly 6" exhaust stack in the bed and installed a thrush turbo w/side dump exhaust. The thrush gave it a little too much hush. Pro comp 6" suspension lift. Got a Meyer 7.5 foot snow plow, a flipper style gooseneck hitch, a cushion ride tag hitch and a 21,000lb fifth wheel hitch.
CGBear is offline
Old 10-21-2009, 06:44 PM   #15 (permalink)
Cjhstang's Avatar
well both batteries tested good and so did alternator. donno what the deal is. the voltage at idle a few mins after turning it on is 13.38.
confusing part is after i shut it down and plugged in the trickel cell charger it didn't seem to charge. infact it was showing a very very slow drop in volts over a few mins of holding my gauge to the batteries. started at 12.59 and slowly dropped to 12.54. i'ma let it on all night and through tomorrow. i'll retest it around same time tom eve.
maybe i have a bad wire somewhere that is draining my batteries?
with my results does it sound like my volt regulator is good?
-3" Body Lift
-8ft snow plow
Cjhstang is offline
