hmm, mine actually isn't grounded by that post. mine is just grounded through its mounts to the engine block. wonder if this could have to do with it....
Do you still have the original cables? If so, they are not helping the situation.
no replaced all wires on the batteries as well as terminals
7.3 IDI F-350 4x4 1990 150k miles
-Custom: '92 interior; '04 Hydroboost brake system; Volt/Temp/Oil Pressure/Oil temp/Trans temp/Boost/Pyro meters; Banks Sidewinder Turbo into 4" glasspack and dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump; Steering Box; Denso Starter
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-Dual 30micron to 2micron filter system... WMO WATF! Free Fuel!!
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
what kicks the dummy battery light? Is it the same sensor as the oem volt meter? my batter light won't go off.
I charged the batteries on trickel cell for 3 days and it finally seems ok, i think i was just never driving far enough or letting it sit on the trickel cell long enough to really get it fully charged.
I just need to get this battery light off.
-3" Body Lift
-8ft snow plow
Now that you have fully charged batteries, what voltage is the alt putting out?
Regards,
Paul - Pocono Mtns. USA
02 E350 15 Passenger, 52,000 Miles
'90 E350 7.3L Ex-Ambulance High Top 400K Miles, No Turbo, Stock Stock stock, No ELC! (Extended Life Coolant) & 10 Oz. Bars Stop Leak, Retired 11/8/2011 with blown trans.
haha, NOW fired her up and have the exact opposite of what the above post has. The battery light was off and i had zero charge from the alternator again. made it to my destination which was about 15 miles away...10 miles into and the volt gauge kicks up, i'm now getting charge again...but the battery warning light comes back on now.
i'm so lost. what else is there to do? rewire it all with all new components and plugs!?
-3" Body Lift
-8ft snow plow
sorry snotz didn't check the voltage at that moment, was in a hurry...and now after my last post i don't have full charge anymore. i have noticed that the dash voltmeter has jumped dangerously high at times tho... like past the l in normal. only for a split second tho.
-3" Body Lift
-8ft snow plow
Curious to see what the end result is here. I'm in the same boat right now with new batts and alternator. It will charge fine, but it seems as if there is a key off draw from the alt charge wire to the starter selenoid and the charge light wouldn't even come on with the key in the on position with the engine off.
Not trying to hijack, but possibly the same gremlin that the OP has.
Early 99 F-250 Superduty X/C SB, 6 speed, South Bend Con OFE clutch, 4" turbo back exhaust, Ebpv Brake Mod, DIY Tymar, Hutch Mod, 2" leveling kit, 315/75/16's, DP tuner ( 60tow, 80econo, 120race, 140extreme), Warn premium hubs, Autometer pyro, boost, tranny, and fuel pressure gauges. AE if anyone in the area needs.
76' (updated) E series 24' Motorhome - 94' 7.3IDI w/ATS turbo (Brand spank'in new turbo spec motor ) ZF 5 speed, LUK clutch, Borg Warner 1356 transfercase, dana 60 front, 3.73 gears, 245/75/16, and its a 4x4 too!
I'll admit that I didn't read all three pages of the thread but I was surfing the web and came across this at Yahoo Motors about a key off trickle charge that could drain your batteries. This sounded pretty general, but maybe this could be a piece of the puzzle. Maybe you have a frayed wire thats making a connection and drawing power.
"Current drain on the battery can be checked with an ammeter. Make sure the ignition is off, then disconnect one of the battery cables. Connect one ammeter lead to the battery and the other to the cable. The normal current drain on most vehicles should be about 25 milliamps or less. If the key-off drain exceeds 100 milliamps, there's an electrical problem that requires further diagnosis."
1993 F350 E40D 7.3 IDI 169k stock stock and more stock.
Yep that's how my buddy, a pro car audio/electronics installer, showed me how to test but on these vans you have to disconnect a cable from each battery otherwise the test won't work. It's best to do the positives on both batteries then put the ammeter between one positive terminal and the positive cable. On one of my cars we found I had wired the MSD ignition wrong and it was always on. An MSD 7AL3 draws a surprising amount of power BTW.
1986 F350 Crew Cab 2wd SRW. 1991 7.3 IDI, T-19 4spd Sterling 10.25 3.55, 12" HD clutch. A Banks waste gated turbo. 5" cut down Peterbilt stack. Midwest rebuilt IP turned up. AC Delco 6.5 GM 12V GP's, working great. Running W85 high performance zero-gel diesel! D60 front conversion, 4wd conversion, dually conversion, and steel flatbed conversion now underway. Man those frame rivets are a pain!
1966 Porsche 911. 1983 911 SC engine with modified Zenith carbs, headers, 911S brakes, custom fuel rails, MSD 6al box with timing computer, 1974 IROC body kit. 1850lbs, 200rwhp, total blast to drive.
well truck has been sitting for a week without being started. started fine today so its shouldn't be battery drain. i was on and off with power from the alternator tho in the 2 mins i had it running today.
...i do not have a ground wire on the regulator...should there be? could this cause these problems? (the regulator is mounted on my firewall infront of the driver) had to move it some time back.
-3" Body Lift
-8ft snow plow
ok well i think i FINALLY found the parasite... had to do with the power lead going from the alt to the battery. not sure what was wrong w it... looked fine.
still can't figure out why my battery dummy light is on??
-3" Body Lift
-8ft snow plow
can rem for sure--but he batt light, has to do with, when the voltage from the batt--matches the alt--the light goes out--thats why it sometimes is dim. one side is less voltage--hence it thinks its ground--and on goes the light--
so would it possibly not be getting a reading from the alt?
-3" Body Lift
-8ft snow plow
wow.. at this point i think i would scrap it all and just go with a 3G..... I did it, happy as can ever be, truck is always 14.4 no matter what... 1992 Ford Taurus 3.8L engine will get you the 130 amp alternator that you want... the alternator housing will have to be rotated about 120 degrees however.. but not hard to do.. you will also need a 3G harness plug (new on ebay for $9, or junkyard one..)
this is one upgrade that truly is worth it.
when the alternator dies that is the plan. problem ended up being that wire. its running great now. its just this stupid battery dummy light is always on. i'm about to just pop the light out of it so its off. FOR GOOD!
-3" Body Lift
-8ft snow plow
