Old 08-31-2007, 10:59 PM   #1 (permalink)
Charging system warning light
Hey yall! A while back I replaced the alternator cuz the light was flickering and the bearings were squeaking. Then I replaced the regulator because the light was flickering and voltage was bouncing high/low. The light's still flickering, whats next [img]/forums/images/%%GRAEMLIN_URL%%/confused.gif[/img]? Or should I finally seek professional help [img]/forums/images/%%GRAEMLIN_URL%%/cry.gif[/img]?
'88 F250 Lariat extended cab ?10,XXXmi, C6 Auto, 3.55 rear, 16" Aluminum Summit Racing Rims, LT235/85R16 Bridgestone Duelers, Sony Xplod CD Reciever, Mostly OEM replacment parts, for now...Lovingly named "Brownie" simply because its brown and a sweet ride .
dieseldude73idi is offline
Old 08-31-2007, 11:01 PM   #2 (permalink)
88beast's Avatar
Re: Charging system warning light
you have a accidental ground that may touch frame and then go off ?
lose wire or something
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
Old 09-01-2007, 01:04 AM   #3 (permalink)
Mine does the same, and I replaced the alternator and regulator with no luck. I was told here the white wire from the alternator is the one that senses current flow and should be checked for a good connection to the alternator.
I finally learned to ignore it and I'll probably yank the bulb next time I have access. My digital volt meter says I'm putting out 14.3 Volts, so I'm not concerned.
A.K.A. Sign_man
1988 F-Superduty bucket truck, 7.3 IDI, LuK Clutch, 5 spd, 4.10 rear
http://photos.thedieselstop.com/show...=70062&thumb=1
Phillipmc1268 is offline
Old 09-01-2007, 05:44 PM   #4 (permalink)
Mine has done that twice. Both times it was an easy fix, pull the electrical connectors off, spray contact cleaner on both sides, reassemble.
'93 F-250, - most original at 252K miles, rebuilt E4OD 220K miles
Greenie is online now
Old 09-01-2007, 08:40 PM   #5 (permalink)
take it to a reg rebuild shop near you--should end your problem--theres a whole lot of bad rebuilders out there supplying the major chains--your hometown guy will normally do it right----
94_turbo is offline
