Clutch Adjustment - Diesel Forum - TheDieselStop.com
post #1 of 23 (permalink) Old 05-16-2007, 09:15 PM Thread Starter
Erk
Clutch Adjustment
I have a 1994 F250 7.3IDI w/ Turbo and 5sp. My clutch has about 10 inches of travel and my slip point is pretty much at the floor board. I was wondering what is the best way to go about adjusting the clutch on this type of trans/truck. Any advice/suggestions are appreciated. Thanks
-Eric
Erk is offline
post #2 of 23 (permalink) Old 05-16-2007, 10:57 PM
Re: Clutch Adjustment
Check your firewall for cracks around the clutch master cylinder. Also check for worn bushings at the top of the clutch pedal.
Being a closed hydraulic system there is no clutch adjustment.
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
post #3 of 23 (permalink) Old 05-16-2007, 11:46 PM Thread Starter
Erk
So there's no way i can adjust it i take it? I do not know much when it comes to clutches/transmissions. Thanks again.
-Eric
Erk is offline
post #4 of 23 (permalink) Old 05-17-2007, 09:35 AM
Well there's no adjustment per se, there's something broken that needs fixed.
post #5 of 23 (permalink) Old 05-19-2007, 08:29 AM
bluefishbeagle's Avatar
This is a good question since I just had the same problem. I removed the slave cyl, fork and lubed everything. The fork needed lube on both pivot points and the throwout bearing contact points. Also was able to get some lube on the tranny input shaft where the throwout bearing slides. After getting it all back together my clutch was much easier to operate and now the clutch engages a little further from the floorboard.
Upon further investigation it appears that I have to much wear in the clutch peddle (cross over) bushings and I'm going to replace those and all should be good.
My truck is like yours except it's a 1993. It's got 114K original miles on it.
1993 F250 7.3IDI Turbo (factory) 2X4 ZF5 4.10 Diff, Floating axle, Extended Cab Long Bed ZeeDee running boards, 185K miles, Second Owner
1999 Victory V92C Overdrive Sprocket, Power Commander, High Compression Pistons, Performance cam. Slash Cut pipes, Corbin Seat, Factory windscreen, Highway bars.
*Commercial pilot and certified aircraft mechanic by choice, Ford mechanic by necessity*
Most iconic aircraft ever built? Ford Tri-Motor of course!! Take a virtual tour
bluefishbeagle is offline
post #6 of 23 (permalink) Old 05-19-2007, 09:39 PM
Ford Stuff
Firewall Flex
When Ford introduced the hydraulic clutch master cylinder in 1984 in their pickups, a rash of clutch release problems starting showing up. The area where the master cylinder is bolted to the firewall is prone to flexing when the clutch is depressed. This can get so severe that it will crack the firewall. If the firewall moves when the clutch is depressed, the volume of fluid to the slave cylinder is decreased which reduces the travel of the throw-out bearing, which will not allow the clutch to release completely. The only repair for this condition is to reinforce the firewall area. A brace for this is available from Ford dealerships. This is a sheet metal part which must be screwed in place. Another style brace is available from many clutch shops. It is made of steel plate and does not require any drilling. It simply mounts behind the master cylinder.
Pedal to Master Cylinder Link
A poor release on a Ford F series pickup with a hydraulic clutch can often be caused by a small link connected to the end of the clutch and brake pedal pivot shaft. This is the link that pushes in the master cylinder rod. The link is simply pressed onto the end of the knurled pedal shaft. Over time, this link will work loose on the knurls and will fail to push the rod into the master cylinder far enough to release the clutch. To check for this condition, remove the pushrod locking clip and slip the rod off the link. Raise the clutch pedal to the top of its travel and try to replace the rod over the link pin. If the pedal must be lowered in order to replace the rod, the link has slipped and must be replaced. Do not try to simply tighten the mounting nut. It will not work. The link must be replaced.
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
David and his Ford truck with a little motor and a big idea......
Ford F-350 Dually Crew Cab 5-Sp 7.3 IDI Centurion Conversion. No mods, rebilt IP and replaced injectors. Used as personal driver and pulling my RV camper.
Planned upgrades are a new and better turbo and larger exhaust pipes than the 21/2s that are already under the rig/ would like a 6 spd tranny but dont know if that is a feasable or smart investment yet.
1993 Dodge 3/4 ton Van Conversion 318CI
1978 Dodge Magnum XE T-top Classic 4BBl 400CI (Honeymoon Car)
1965 Dodge Polara 4 DR 383CI
AmaMoparmanbutlikeForrrrrdtrucks
truckdrivindave is offline
post #7 of 23 (permalink) Old 05-20-2007, 03:27 PM
Good post! Just one correction. I think that 1984 date is a little off. My 1983 parts truck has a hydraulic clutch in it....
Sorry to all the loyal 7.3 guys, but I traded my '91 7.3 in on a 2002 F250 Ex cab V10 4x4. SCT Xcalibrator2 with tunes by Powerplay Performance. 285/75/16 Toyo M/T's. Took a long time to get used to the ping-pop of a cooling catalytic converter...LOL.
'85 Bronco swapped up to a 302 4bbl from the 300 I6, NP435 4spd, NP208, 32x11.50x15 Radial RVT's, Soon to be 6.9 turbo powered.
86 F350 Cab&Chassis with a dump bed. 2wd 6.9 and 4 spd tranny. No mods to engine.
2000 Volvo 660 N14 Cummins, 500hp 1650 ft lbs, Autoshift tranny 10spd.
What part of "SHALL NOT INFRINGE" do you NOT understand?
aceohearts is offline
post #8 of 23 (permalink) Old 05-20-2007, 07:54 PM
cdnsarguy's Avatar
My Photos: (109)
Check all the pivot points on the clutch pedal arms, I'm sure some are worn out.
Proud Canadian BOOB man too!!
cdnsarguy is offline
post #9 of 23 (permalink) Old 11-18-2014, 03:09 PM
I'm having a similar problem except my pedal slips as soon I touch it can any adjust be made and 3rd-5th while driving slip with a touch of the pedal 1st-2nd doesnt
trusty rusty trail rig is offline
post #10 of 23 (permalink) Old 11-18-2014, 07:41 PM
This is a very old thread, my truck now has 175K miles and since my earlier post I've replaced the slave and master cylinders plus the shiftling fork, and pivot stud. I did replace the crossover bushings as mentioned in the first post plus I found a broken weld in the mounting bracket. After rewelding bracket my clutch operated much better. My clutch peddle travel is normal and very easy to push. Clutch peddle problems in these trucks mean you have maintenance issues. The only fix is time and money. If you do your own work its not bad at all.
post #11 of 23 (permalink) Old 05-23-2015, 08:35 AM
Does anyone know how to get free play on these clutches - 1994 F450 ?
sloandf09 is offline
post #12 of 23 (permalink) Old 05-23-2015, 09:56 AM
As near as I can tell the free play is pre set. I seem to recall the 1985 model had an adjustment at the link between the slave cylinder, and the fork, but I haven't seen them on any newer models.
oldrebuiltdodge is offline
post #13 of 23 (permalink) Old 05-24-2015, 04:00 PM
I examined my master and slave cylinder yesterday. Removed and inspected both. It appears that the slave cylinder has a built in return spring thus when the fluid pressure from the master cylinder and the spring pressure form the clutch pressure plate are released the slave cylinder rod continues to move out of the slave cylinder until it reaches max stroke to make full contact with the arm that come out of the clutch housing. Therefore the slave cylinder rod will always feel like it has pressure on it.
I now need a measurement between two components to know if the pressure plate is fully releasing and thus fully engaging the clutch disc.
post #14 of 23 (permalink) Old 05-24-2015, 06:00 PM
See if you can turn the throw out bearing with the clutch engaged.
post #15 of 23 (permalink) Old 05-24-2015, 08:23 PM
My Photos: (27)
I never really feel any free play with the hydraulic system like you do with mechanical linkage. But I'm convinced it's there, otherwise my original throwout bearing wouldn't still be going strong at 247,000 miles.
LMJD is offline
