Old 04-03-2008, 08:29 PM   #1 (permalink)
Clutch pedal bushings
Does anyone have Ford part #'s for the clutch pedal bushings or where they are available from other sources ? The parts guy at my local dealer has no idea and I really need a set. Any help is appreciated
94 F-250 XLT 4X4 REG. CAB , TINTED WINDOWS , PIONEER SUPER TUNER 3 WITH INFINITY GOLD SPEAKERS , FACTORY TWO STALL SPIT CUP HOLDERS, 7.3 FACTORY TURBO , REMOVED E4OD & ADDED ZF 5 SPEED , E4OD MAKES A GREAT PAPER WEIGHT , 4" SUSPENSION LIFT , SKYJACKER HYDRO SHOCKS , DANA 60 STRAIGHT FRONT AXIL ( FINALLY ) , 3"DOWNPIPE 4"EXHAUST KIT , 36" X 14.00" MICKEY THOMPSONS ON 16.5" ALUM. WHEELS , GOOSENECK HITCH EQUIPED , A-PILLAR GAUGE MOUNT WITH BOOST , PYRO & WATER TEMP. Totaled in April of '06
1992 F350 CC Dually XLT 7.3 NA with a broken Banks Sidewinder kit, gooseneck and reese hitchs, 234,000 mi and still going strong
2005 F-350 CC single wheel XLT Lariet 6.0, AT with ALL the goodies in the cab
JAYSON is offline
Old 04-03-2008, 09:33 PM   #2 (permalink)
My experience with the Ford bushings is that these are worthless.
It is likely you have worn parts.
Throwing money out the truck window is far better then giving the money to Ford.
$5 for a piece of plastic, junk.
The design was bad, and I am being generous.
Get on your back and look for worn parts.
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
BuilderBob is offline
Old 04-03-2008, 11:38 PM   #3 (permalink)
I just went to my local dealer and told them I needed pedal bushings, they knew what I was talking about.
But, to add what builder bob said...
If you can, pull the pedal assembly first. I took mine out and the bushings were actually fine. I took it apart and put some grease and graphite in it. Where I did have a problem was on the clutch rod end- the (plastic) bushing was destroyed, the pin on the clutch pedal arm was all chewed up, and somebody had it held together with wire.
I cut off the old pin and drilled it out, put in a steel pin, bronze bushing in the clutch rod, and some grease and washers. Somebody else told me they did this and the bronze bushing also wore out. I guess I'll see what happens.
BTW I did this because I had a really stiff clutch pedal, it feels a little better but I haven't driven it yet. If you search in the forum for "solving stiff clutch pedal" you should find my original thread which had a pretty good discussion about the whole thing.
'94 F250 XLT- IDI Turbo, 5 speed, 4x4, manual hubs. ATS upgrade, 3" downpipe, 4" exhaust. Autometer pyrometer & boost gauges. More coming.
'87 Thunderbird Turbo Coupe
Lots of mods & pretty quick.
ghunt is offline
Old 04-04-2008, 09:53 AM   #4 (permalink)
mm
check out these earlier post
Solving stiff clutch pedal - Page 3 - Diesel Forum - The Diesel Stop.com
1992 F250, 5 speed, extended cab, replaced 7.3 with 6.9 2-5-08
DewEze round bale carrier
mm is offline
