Re: Clutch Pedal Push Rod
What CDN is saying is that a lot of clutch release problems on these trucks come from excess pedal pressure, which is often caused by the snout on the front of the trans where the throwout bearing slides getting dry and gummy, raising the pedal effort. I have seen all kinds of busted parts including the firewall on account of this. If you pull the clutch fork and boot out of the bell housing, you can reach in and see if the TO bearing moves smoothly, and if not spray some lube on it and get it freed up.
Diesel Mechanic 28 yrs
