Clutch Problems?
Hi all... new to the forum. I just returned from a trip around the state towing a travel trailer. Periodically, I experienced chattering when starting out from a stop. Some in 1st gear, most noticable in 2nd. I didn't notice any slippage as such, just the chatter. It always seemed to happen after driving several hours. Also, it was in the mountains, so lots of upshifts/downshifts and it was hot. No problems with shorter or less strenuous drives. I assumed it was the clutch, but after some research I'm wondering if the dual mass flywheel might be the problem. Is there anything else I should be checking? The truck is a 1993 F250 4x4 with about 91K miles on it.
Assuming the worst case, the LUK solid flywheel kit sounds like a pretty decent setup. However, I'm concerned about the gear noise issues. What's the deal with that? Is it noticeable at highway speeds or is it just at idle? Is there significant vibration? I would be very interested to get some feedback from anyone who has gone this route.
Thanks!
1993 F250 Super Cab 4x4, 7.3IDI, 5sp, ATS Turbo, K&N Filter
