Old 03-15-2006, 09:45 AM   #1 (permalink)
Clutch Problems, help.
it all started when somehow my dust cover got caught on my flywheel and it bent it all to shreads. since then i have dropped out at least three clutch springs. i think i only have one left because that is all i can see. and it is really loose in there, i can wiggle it 3/4 inch both ways. what is causing this. what clutch will work. will one from a stock powerstroke work. the hell of it is that the clutch still seems to work fine. i need help im only available to work on it saturday and sunday. by monday it has to be figured out.thanks fellas in advance.
1990 XLT F250 4x4 5 spd. Regular Cab 7.3 IDI - 2 inch lift, Dayton Timberline M/T 285/75R/16, 4 inch single stack (meiter cut), tweaked pump, timing advanced 3 deg, loaded wood grain interior, Luck Mod Flywheel More To Come!!!
PICTURES - http://community.webshots.com/myphot...ecurity=SCqlbu
studbacker is offline
Old 03-15-2006, 11:45 AM   #2 (permalink)
Re: Clutch Problems, help.
Your dual-mass fly wheels is going bad. Mine did the same thing. It spit out springs for almost a year. When I finally replaced it there was not one spring left, and like yours it still worked. I would buy the LUK single mass flywheel. I've been very happy with mine. I would think you could pull the trans off and have the flywheel and clutch installed in about a day.
1992 F-250 Supercab longbed 4x4, NA, manual trans. 325,000 miles. Slowly restoring everything on truck. Items repaired/replaced so far...new alternator, starter, batteries, beru glow plugs and new controller, new injectors and fuel lines, LUK solid mass flywheel(12"), Warn manual hubs, Completely new AC system(new comprssor, evaporator, dryer, condensor, all hoses r-134), new front rear wheel bearings, new 3" exhaust, new power steering pump, new IP, new vacuum pump.
NCFORD is offline
Old 03-15-2006, 02:15 PM   #3 (permalink)
thanks man because you know how it is. on my short time off i cant tear down till i have the part already to put back in and i cant do that unless i know whats wrong with it before i tear down.thats where good guys like you and the other members on this fourm help me and others out. i appreciate you and everyone else that helps out. well now that i got the good out of the way, how much is this going to cost me cause i was just getting ready to buy a turbo kit. thanks jake
Old 03-15-2006, 02:44 PM   #4 (permalink)
I just did mine on my truck I also replaced the rear main seal as well since I had the tranny out. If I were you I would replace the rear main at the same time so that you dont have to pull the tranny again if it starts to leak. I also went with the Luk conversion with the solid flywheel and clkutch kit that included clutch pressure plate pilot and throwout bearing was like 54.00 shipped to my door. you have an 11" stock clutch kit and this will upgrade you to the 12" which will be better for pulling. It took me about 4 hours of solid work to pull the old one and get the new one in. the worst part on mine was the turbo downpipe was in the way
Ramnon
1993 f350 SRW Crew cab 2wd 7.3 with factory turbo
zf5 trans
RamonF350 is offline
Old 03-15-2006, 05:08 PM   #5 (permalink)
Ramon's price is off a decimal place.
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
aaklingler is offline
Old 03-15-2006, 05:53 PM   #6 (permalink)
The "Lucky Mod" may be a better alternative if money is an issue (when isn't it). I believe all parts are left stop with the exception of the clutch disk, which must be the spring type to replace the springs in the dual-mass flywheel.
Poke here http://forums.thedieselstop.com/ubbt...v=#Post2782814
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 03-16-2006, 11:37 AM   #7 (permalink)
oopps [img]/ubbthreads/images/graemlins/blush.gif[/img] [img]/ubbthreads/images/graemlins/blush.gif[/img] sorry about that I wish it was only 54.00 but he is correct it was 540.00 shipped but still a dang good deal if you ask me and the people at dial a clutch are great they answered all of my questions and were very prompt shipping the parts.
Ramon
zf5 trans
