Clutch Safety Switch - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 01-30-2012, 09:41 PM Thread Starter
I think my clutch safety switch just puked. I would like to eliminate it. I don't have a wiring diagram for it and need to know which wires I need to splice together to make the truck start.
89 F250 XLT Lariat 7.3 idi 4x4 ZF5 speed Supercab Long box Sterling 10.25 4.11. Too many new parts to list. 300k+ and still running great.
Wish List: Paint, Turbo, Spray-in Bed-liner, Custom Bumpers
Mike_20 is offline
post #2 of 5 (permalink) Old 01-30-2012, 10:33 PM
chuckster57's Avatar
I went looking and I found a site that says to cross the red and yellow to bypass it.
AND now I found another that said to connect the BLACK and red together. Hope someone chimes in with the right answer. I have had auto trannies in my trucks since 1986.
Train Horns:
PM please not visitor message
chuckster57 is online now
post #3 of 5 (permalink) Old 01-31-2012, 05:43 AM
My Photos: (27)
You have to jump (join two wires). There's four at the switch, the other two are for the speed control cutout when the clutch is depressed. The correct two can be determined with a test light.
LMJD is offline
post #4 of 5 (permalink) Old 01-31-2012, 01:10 PM Thread Starter
I got it figured out. Thanks for the advice. For future reference you have jump the two red wires. The two green ones are for the speed control cutout as LMJD pointed out.
Mike_20 is offline
post #5 of 5 (permalink) Old 01-31-2012, 02:39 PM
NH2112's Avatar
Send a message via MSN to NH2112 Send a message via Yahoo to NH2112
The start circuit wires should be red w/blue stripe, but it can be a little hard to see that we'll under the dash.
Phil
Check my lists of common part numbers in my photos! Updated often!
1991 F350 Lariat XLT, 7.3l, 5-speed, crew cab, SRW, 3.55, 2WD.
1990 Jeep Wrangler Sahara, in the process of a major overhaul/upgrade. OM617 on the horizon! Front & rear Dana 44s from a Wagoneer till I get some 1-ton axles built & narrowed, and eventually a front shackle reversal. Diesel YJ, bay-BEE, and not a cookie-cutter 4BT conversion!
NH2112 is offline
