Old 09-01-2007, 11:05 PM   #1 (permalink)
code help ,and tranny ?? please
a couple weeks ago I made a trip to Georgia and hauled backed 4 seadoo's ,about half way back the od light started flashing and lasted for a couple days and tranny shifted fine again haled a few loads of scrap with no problems but the last load I went on the interstate with a empty trailer and the od started flashing again
Here are the codes I got
23
14
62
68
Is there a quick fix for these or can somebody tell me what I need to fix them ?
I just picked up a 1990 with a 7.3 for parts and its codes are
23
67
is there anything i can use of this truck to fix my other one?
Also on the 90 parts truck the tranny has no reverse (it trys if you stand on the throttle)Is there any kind of quick fix or is it rebiuldable or trash?
thanks for any help
91 F-350 XLT Lariat Supercab Dually
7.3 Auto w/ATS Turbo
meanmudder is offline
Old 09-02-2007, 10:19 AM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: code help ,and tranny ?? please
Emailing the codes........ check them out and get back to us.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 09-03-2007, 01:53 AM   #3 (permalink)
I had these codes after my trans rebuild last month. If I'm not mistaken, the 23 is TP Sensor, and 67 was PNP Safety switch. I replaced both items and still had the codes. I found the adjustment procedures for both on this forum and made the adjustments. The PNP sw error went away, but I still get the 23. Today I realized that the OD light only flashed during decel, throttle at idle. I could increase throttle slightly and the flashing stopped. I believe that either the voltage meter I used could be slightly out of calibration, or there's a small voltage drop in the wires. Tomorrow, I'm going to adjust the idle voltage from 1.1vdc to 1.2 vdc and see if the error goes away.
Hope this helps.
'94 F350 Dually 7.3 <span style="color: blue"> IDI </span>
<span style="color: red">Banks Sidewinder & Trans Command, 3.5" Exhaust </span>
<span style="color: blue">Gear Vendors Over/Under Auxilary Trans </span>
<span style="color: green">Gambler 209 (THE Ultimate Bass Boat)</span>
Lance 880 Camper
cre8ive is offline
Old 09-03-2007, 11:18 AM   #4 (permalink)
cdnsarguy's Avatar
My Photos: (66)
How old is the FIPL........
DIESEL FIPL SENSOR INFO
DATE 1992
REASON
Early Black FIPL has High Failure Rate
RECOMMENDATION
Always replace the black colored early FIPL or any colored FIPL having 60 thousand or more miles with the late gray colored FIPL.
PART NUMBER
F2TZ-9B989-C
Old 09-06-2007, 01:29 AM   #5 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: meanmudder</div><div class="ubbcode-body">a couple weeks ago I made a trip to Georgia and hauled backed 4 seadoo's ,about half way back the od light started flashing and lasted for a couple days and tranny shifted fine again haled a few loads of scrap with no problems but the last load I went on the interstate with a empty trailer and the od started flashing again
23
14
62
68
23
67
thanks for any help </div></div>
<span style='font-size: 14pt'>68 is the big trouble and will trip the others. Overheating. 62 is slip. Examine the fluid. Hopefully it's not burn't. Unless the fluid sensor is bad, fluid temps hit 280+ degrees. If caught in time, you need a new bigger tranny cooler and a check for clogs.
The other truck's codes are related to the MLPS. Sensor on shift lever. You really need to tear them down to see if they are rebuildable. No R could be just seals or pressure loss from any source.</span>
The Racer X Built E4OD THAT CAN Video. 1997 F-350 7.3 Twin Turboed Power Stroke Diesel. Fueled with 473 + cc's of Diesel and nitrous!
Family owned & sponsored by : FloridaNorth
For Fuel - D.J. @ DIY-injectors.com
"AMERICAN INGENUITY " Half of AMERICAN is I CAN."
Racer_X is offline
Old 09-06-2007, 01:40 AM   #6 (permalink)
cdnsarguy's Avatar
My Photos: (66)
No reverse can be:
Fluid level/condition
Shift linkage damaged/misadjusted
Improper trans pressures/low line pressure
Oil filter and seal assy....**
Thats about it for the shadetree mechanic the rest is very deep internal stuff.
Old 09-06-2007, 12:30 PM   #7 (permalink)
set the tp and got 1.1 to 3.8 cleared the computer got about 50 miles on it now and got a code 14,any fix for that?
is there any way to test the pressure for the reverse problem?
Old 09-06-2007, 02:58 PM   #8 (permalink)
cdnsarguy's Avatar
My Photos: (66)
14 is a RPM sensor failure.........Check it
A dead tach sender should/would send the automatic trans into a "failure management mode" (limp mode) with harsh engagements and firm shift feel and an abnormal shift schedule. It has no effect on a manual trans only the Tach readings.
Check the wires where they exit the big nut on the oil filler housing , known to short out due to bare wire.....
Replace the tach sender on the oil fill housing a big 1" nut with 2 wires. Ford only part Engine RPM sensor E5TZ-17B384-A about $50. You can remove and clean it but usually changed later too.
You can test it too, hold it in the air away from ferrous metal, using an ohm meter lead on each wire you need DC resistance between 2000-3000 ohms.
