Old 03-11-2005, 09:25 AM   #1 (permalink)
Send a message via ICQ to fordrox
colant in crankcase
hrers the low down, lets see if i can tap the infinate wisdom of the idi basement for this one?
the coolant is dropping at a rate of 1.5-2 gal per hour of highway driving
it will sit and run for an hour at varring throttle speeds (mainly idle)and not loose any coolant
if i drive for a short distance and take off the rad. cap and look, there is lots of white bubbles -a little foamy on the top
no excessive press in the coolant system but some
could the rad be restricted letting the wp "suck" in air and blowing coolant past the gasket?? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
im going on a long trip soon and want to get this fixed first!!
thanx in advance, this is giving me a headache [img]/ubbthreads/images/graemlins/tongue.gif[/img]
mine - 1992 f250, 7.3 zf5 close ratio, 4*4, 4.10 gears,ext cab, long bed,reman 1994 IDT engine, and ats turbo to boot!!(insert grunting sound here!!)291100 and counting
dads - 1990 f250 2wd, ip may be tweaked, stage 1 injectors? maybee, 7.3 zf5 wide ratio,stock, needs paint and pyro.
grandpa's - 1989 f250 7.3, e4od, 4" straight pipe roar, 2wd stock, not planning on many mods.
pulls a 5w 20? ft camper, or bumper tool trailer\wood hauler(heats w\ wood)
fordrox is offline
Old 03-11-2005, 10:46 AM   #2 (permalink)
My Photos: (23)
Re: colant in crankcase
Man I hate to say it, but it sure sounds like caviation. Some tests to do.
On each cylinder, position the piston at TDC, and presurize the cylinder with compressed air through a glow plug hole adapter. You'll need to hold the crank still somehow for this. Check the rad. If no bubbles, repeat the test with the piston at BDC. If no bubbles, go to the next cylinder and repeat. If you find bubbles at TDC, then it may be a cracked head or bad head gasket. If bubbles at BDC, start pricing a short block. [img]/ubbthreads/images/graemlins/crazy.gif[/img]
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 03-12-2005, 10:34 AM   #3 (permalink)
i hope not - it all looked ok when i had it apart
any other ideas, there is no indacation of coolant in the cyls whatsoever
could it be the 4 wp bolts?
i think the front timing cover may have incured a few scratches when cleaning it [img]/ubbthreads/images/graemlins/blush.gif[/img]
not to mention i dont have many diagnostic tools or air compressor [img]/ubbthreads/images/graemlins/shrug.gif[/img]
or much time
fordrox is offline
Old 03-12-2005, 07:02 PM   #4 (permalink)
help please
fordrox is offline
Old 03-12-2005, 07:17 PM   #5 (permalink)
cdnsarguy's Avatar
My Photos: (66)
This comment in your signature bothers me.....
just did a complete gasket set due to head gasket failure...fun w\no garage!!
Was it really head gasket failure, did you see the failure point and did it jump out at you visually, or was this just a guess by some shade tree mechanics.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 03-12-2005, 07:19 PM   #6 (permalink)
Can you go through what your symptoms were before and what all you did to it, you can try pulling the water pump and checking it out, did you put sealant on the threads, but i would recommend finding somebody that can do the test Mel stated, did anybody do anything to your heads while they were off?
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
aaklingler is offline
Old 03-12-2005, 07:21 PM   #7 (permalink)
the coolant passages were shriveled and the guy at napas machene shop said he could see it , w\o me saying any thing
fordrox is offline
Old 03-12-2005, 07:23 PM   #8 (permalink)
magna fluxed and surfaced
fordrox is offline
Old 03-12-2005, 07:49 PM   #9 (permalink)
In my opinion ya got to get it up to temp let it cool a little then remove the G plugs and turn the engine over with the fuel pump wire disconected and see if there is any coolant comeing out the gp holes.
As Mel stated it sounds like a cavitation problem!The oil cooler is a vague possablity!
86 F250,SC,4x4 Patched and patched and patched!335000 km and still patchin!
Fred
Fred Hemer is offline
Old 03-12-2005, 08:25 PM   #10 (permalink)
the only time there is any white smoke is when it is cold outside
the water in crank case evaporates and steam burns trough the cdr , white smoke
i realy doubt its the big "c" as it will sit for two days and not loose any coolant
the only time there is coolant loss is when driving , it sat at idle for 30-40 min. and did not loose a drop, went for a 10 min drive and it lost a half gallon
this is very weird, i know, but thanx for all the help
what next [img]/ubbthreads/images/graemlins/shrug.gif[/img]
fordrox is offline
Old 03-12-2005, 09:41 PM   #11 (permalink)
Definitely don't drive it anymore. If your oil turns to chocolate milk, you'll be replacing everything.
Do the test Mel suggested. At idle the cylinders might not have enough heat/stress to open up a pinhole, but it might while driving.
Old Brown--'85 F250 C-6 2WD Reg. cab 2.5 dual exhaust magnaflow muffler, ram-air just like ziggs FOR SALE
That Damn Truck--84 F250 ext. cab XLT C6 2WD 6.9 from DPS, Banks and PSD turbos plumbed in series (ready for tweaking), new paint, lots of money and time and I'm still not done.
75 F250 hiboy 4X4. yard goat 360 CI C6 custom steel flatbed, doghouse removed replaced with flat sheet metal, all wiring removed, no key necessary. "The Beast" OSHA approved, though.
'02 Excursion Limited. No mods yet
flatlander is offline
Old 03-13-2005, 04:11 PM   #12 (permalink)
ok, where can i get a compression tester
fordrox is offline
Old 03-13-2005, 07:00 PM   #13 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Check out this tester.... Tools
Magnafluxed and SURFACED [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/eek.gif[/img]...how much did they remove. What was their overal thickness of the heads after surfacing.
I do have info from AERA (American Engine Rebuilders Association) which states the IH/Nav minimum head thickness after dressing/milling should be no less than 4.7950".
Old 03-13-2005, 07:35 PM   #14 (permalink)
0.007 on one and 002-003 on the other
fordrox is offline
