cold air intake for 7.3 idi's - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 11-19-2008, 09:55 PM Thread Starter
does any one know where to find them or if a powerstroke intake will fit on the 7.3 idi's
Crain16 is offline
post #2 of 3 (permalink) Old 11-19-2008, 11:18 PM
try looking for that at Auto Parts and Discount Truck Parts at Car Parts Wholesale.com they might help you.
BARNETTPerez is offline
post #3 of 3 (permalink) Old 11-20-2008, 10:14 AM
Cjhstang's Avatar
i'd double check before you order that... i c it says its for the 7.3 but if you read the description it doesn't sound like its for a diesel. if it is its prolly just the filter. most guys build their own cold air intake. many run it down beside the radiator. Banks has a larger filter housing that "should" increase air flow. until you get a turbo on it you prolly wont see a difference. since i did my body lift i haven't used the plastic part of the intake. so my air is pulled in directly from underhood temps. haven't seen ANY diff in performance or mpg.
F-350 4x4 1990
-'94 overhauled 5.9 Cummins
P7100 Injection Pump w/ 4kgsk, 60lb valve springs, Hamilton performance cam, HX40 turbo, ARP head studs, New marine pistons and injectors, FASS system lift pump
-Homemade oem & engine harness with Dual electric fans
-'92 interior; '86 front clip; '04 Hydroboosted front and rear disc brake system; Slew of autometer gauges; dual 4.25" Stacks
-Rebuilt and upgraded my E4OD - billet input shaft and T.C. Remote mount Derale dual layer trans cooler; Baumann Trans Controller and Harness
-3" Body Lift, Cut-Out Bushwacker Fender Flares with 16x10 Eagle Alloy 186 on 33's
All done in the driveway and basement...
Cjhstang is offline
