cold air intake for 7.3 idi's - Diesel Forum - TheDieselStop.com
Old 11-19-2008, 10:55 PM   #1 (permalink)
does any one know where to find them or if a powerstroke intake will fit on the 7.3 idi's
Crain16 is offline   Reply With Quote Quick reply to this message
Old 11-20-2008, 12:18 AM   #2 (permalink)
try looking for that at Auto Parts and Discount Truck Parts at Car Parts Wholesale.com they might help you.
BARNETTPerez is offline   Reply With Quote Quick reply to this message
Old 11-20-2008, 11:14 AM   #3 (permalink)
Cjhstang's Avatar
i'd double check before you order that... i c it says its for the 7.3 but if you read the description it doesn't sound like its for a diesel. if it is its prolly just the filter. most guys build their own cold air intake. many run it down beside the radiator. Banks has a larger filter housing that "should" increase air flow. until you get a turbo on it you prolly wont see a difference. since i did my body lift i haven't used the plastic part of the intake. so my air is pulled in directly from underhood temps. haven't seen ANY diff in performance or mpg.
F-350 4x4 1990
-'94 overhauled 5.9 Cummins P7100 Injection Pump w/ 4kgsk, 60lb valve springs, Hamilton performance cam, HX40 turbo, ARP head studs, New marine pistons and injectors, FASS system lift pump
-Homemade oem & engine harness with Dual electric fans
-'92 interior; '86 front clip; '04 Hydroboosted front and rear disc brake system; Slew of autometer gauges; dual 4.25" Stacks
-Rebuilt and upgraded my E4OD - billet input shaft and T.C. Remote mount Derale dual layer trans cooler; Baumann Trans Controller and Harness
-3" Body Lift, Cut-Out Bushwacker Fender Flares with 16x10 Eagle Alloy 186 on 33's
All done in the driveway and basement...
Cjhstang is offline   Reply With Quote Quick reply to this message
Wheel & Tire Center
Powered by vBulletin® Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
