Old 10-10-2006, 04:26 PM   #1 (permalink)
cold idle advance
hey all~
anyone know why when I plug in my cold idle advance I lose power going to my cold idle solenoid(fast idle)???
is this a low voltage condition?
thanks
mike
'94 SC LWB 4x4 Factory Turbo, 5 speed, 4.10's, LuK SMF clutch, HOMEMADE straight piped, tool box, dual antennas, NEW ATS Aurora 2000 Turbo. Does GREAT after a wastegate adjustment. Pulling down over 20mpg lately.
graytrain is offline
Old 10-10-2006, 05:46 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: cold idle advance
Do you have power to all three wires with the key on, cold engine. The FIS and CTA are on the same wire, should have 12V from the engine temp switch behind the upper coolant manifold until engine temp reaches 112*F.
You may have a dead short in the CTA solenoid. Have removed the IP governor cover at all, if so you may have an isolation washer in the wrong place...... If YOU did not take the cover off, or this problem has existed for some time. PM me yor email addy.....I will send a TSB.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 10-11-2006, 12:59 AM   #3 (permalink)
My Photos: (17)
The ORDER of connection may be wrong.
To check the connections to the IP, here's what you need to do. Turn on key to 'run' position. Check the main wire that comes from the loom to the IP (injection pump), does it have juice. The wire runs to the FSS (fuel shutoff switch) connector first, then to one side of the Cold Engine Switch(two-prong sensor, located in hole behind the upper radiator hose connection). When the engine is cold 'juice' will pass thru the sensor, if the sensor is good, and go to either the FIS (fast idle solenoid) or the CTA (cold timing advance), then to the other. If the engine is cold and sensor is good it will be 'closed' and allow 'juice' to get to the FIS plunger which holds the idle speed up. If FIS plunger is working, but not pushing up far enough, use a 1/4" wrench to turn/extend it until the idle speed is ~1000 rpm. The CTA (cold timing advance) near the spider/distribution end of the IP 'advances the timing' to make engine run smoother/run cleaner/less smoke. The Cold Engine Switch opens/shuts off the electricity to the FIS and CTA after engine reaches 112 degrees, and engine speed/rpm will/should drop to ~650 rpm. If these three items are working correctly, when you go to start engine, hold the throttle pedal at least 1/2 way to floor to allow the FIS plunger to 'set' itself. Use a test light to check for electricity/juice at each of the solenoids, FSS, FIS and CTA. Let me know if this helps. Good luck, OkieGringo
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 10-13-2006, 10:26 AM   #4 (permalink)
Yes, cold engine I have power to all 3. The temp switch seems to be working (test light verified power)
I havent' pulled the governor cover off due to the IP being rebuilt not more than 10K miles ago! I can see how an isolation washer in the wrong position would cause this. I have had this problem for a while. I dont know if I would necessarily condemn it to the pump but it seems logical at this point. The pump shop did say that my CIA in my old pump was wasted!
PM sent CDN and Thanks guys.
Mike
Old 10-13-2006, 01:56 PM   #5 (permalink)
Does anyone ahve a part # for this 2 pronged switch? is it a ford item, or local parts place?
1990 F-350 Dually 4X4 CC Rebuilt Turbo and NEW 7.3L DAS engine, rebuilt rear diff, Reman E4OD Stage 1 injectors Stage 1 pump Baumann recal kit and TDC for E4OD dead trans again...
2004 F-350 4X4 CC 6.0 PSD
2004 Wilderness 320dbhs TT
DSBlack is offline
Old 10-13-2006, 02:10 PM   #6 (permalink)
cdnsarguy's Avatar
My Photos: (66)
The engine temp switch is known as.......
E8TZ9E939A $48.00 sell $36.00
SWITCH FUEL INJ SYS
Old 10-13-2006, 02:18 PM   #7 (permalink)
Mine broke 200,000 miles ago,
Do you really need it?
I don't need it
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
BuilderBob is offline
Old 10-16-2006, 08:45 PM   #8 (permalink)
Hi Mike,
Did you get this figured out? I have exactly the same problem. It started out intermitent but is now not working at all. Winter is fast approching and I will be doing return line seals (again) this week and want to fix this while I am in there.
CDNSARGUY, hi, how are things? Any chance you could email me the TSB you have?
I have measured the voltages described above and only have 12V going to the IP. Only see 2.5V on the temp switch, both wires, so the switch is fine. What does the IP do to the voltage once it gets inside there? I could sure use a wiring diagram for this, then I could figure it out myself.
Cheers all,
Paul
'93 F250 4X4 EC HD with Banks Turbo, BD Engine Brake, Full Gauge Pod, All Stainless Flowmaster exhaust, New rad and nice fresh '96 E4OD thingy with lot's of mods and soon when it STOPS SNOWING a new IP and injectors.
My Gallery http://photos.thedieselstop.com/show...at=500&thumb=1
ve7khz is offline
