Re: colored bulb for dash back lighting?
No, there would be no point in different colored bulbs for the dash backlights. The dash bulbs are clear, and the transparent plastic is green- giving you the color you see at night. About where to tap into for your dimmer switch- pull your fuse panel off and look at the circuits. Go to any place that has electronics stuff and you can get some piggyback fuse taps. They're little brass things that slip over your ATC fuse with a .250" male connector at the top so you can tap into a circuit easily. I just make sure I fuse mine on the FUSED side, if you know what I mean. Use a test light or a voltmeter to check which side has power when the fuse is pulled. [img]/ubbthreads/images/graemlins/smokin.gif[/img]
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
1997 Dodge 3500: 2WD Cab & Chassis, 12V Cummins, 47RE Automatic, Dana 80, 194,000mi. Parting out.
1989 12V VE Cummins out of Chevy C60? at the machine shop...going into the Ford.
Member of Indiana Air National Guard 122FW MXS
