I have an 89 super cab F-350 2wd 5-spd with the 7.3, and I have been racking my brain trying to chase rabbits with this thing. First it was the over heating, then the alternator, then the glow plug controller, now I think I'm not getting enough fuel.. It cranks up easy, idles like a brand new one, but when I start driving it, the truck starts running really rough, it gets that "hard diesel sound" then it starts shaking really bad then I loose power until it cuts off. When I try to start it again, it acts like its out of fuel for several mins. I have replaced the fuel filter, I have bled the valve on top of the filter, and diesel pours out, never any air. So now I don't know where to look, this truck is all stock no mods at all with 73000 miles on it, if I can get it running 100% then I will start adding fun toys and parts to it but until then... I lost!
remove shrader core from test port on filter head, run a line into a jar
1/3 pint or more after 10 sec. cranking
then hook up a pressure gauge, 4-6 psi within 10 sec. cranking
if either test fails, replace the lift pump
If not, your injection pump could well be going; no start while hot is a common symptom.
So today I thought to switch from the rear tank to the front, and I babied it up and down the block a few time, no problems, then I picked up the pace until I was driving it like some sort of hotrod... Still no problem, so I think that it may just be a problem that's isolated to the rear tank, any ideas?
How much fuel is in the tank(s). The pick-ups breaking off are a known issue and can give you no fuel symptoms at about 1/4 tank. Another possibility is the selector valve not fully seating in one direction.
Train Horns: Pictures here
I'm not sure as to how much fuel is left in the rear tank, I do know that I have been running off of it for a while... So it sounds like I need to pull the bed and check out the pick-up , and maybe the sending unit...
You can just run fuel lines from the tank of your choice, just bypass the selector valve. Make sure you bypass both the delivery side and the return side.
Not a bad idea, what does the fuel pick up look like, is it just a line run to the bottom of the tank right? Also, how do you tell if the brake booster is going out or if it's the vacuum pump?
the pickup foot is a ridiculous goofy piece of rubber with a bypass valve installed in the side of it that will eventually disintegrate and cause problems, with massive holes in the bottom.
