Mel (agnem) has a great Article on removing the heads for head gasket replacment. But, that will still apply to taking the heads off. Be sure to remove the head in reverse torque sequence, otherwise, you could warp or crack the heads! [img]/ubbthreads/images/graemlins/eek.gif[/img] [img]/ubbthreads/images/graemlins/vomit.gif[/img] If you don't have a manual (like Haynes) that gives you the sequence, some one on the site will have a link to it for you.
Did you find any problems when you removed the valve covers? Keep us up to date on what you find.
Heath
__________________ 1986 F250HD 4x4 7.3L IDI '95 PSD front clip, '97 bed, T19, D60/10.25 with 3.55's. Rebuilt from the frame up. Banks Turbo, DPS IP & Stage 1's, Isspro TTM, Banks Exhaust, Boost gauge, Pyrometer, Precharged Coolant Filter, Holley Red Pump. 16.5 x 37 x 12.5 Goodyear Wrangler's, Air Horns. 6in lift, Fresh Paint, On-board Air. Revamped Interior. Rhino Liner.
I would exhaust all other possibilities, before removing the heads.
It does not sound correct, 1 cylinder having 0 compression, and no other symptoms.
'93 F-250 IDI, 4x4, K&N, no soup bowl, stock, with 265,XXX miles 5 speed, 3.55, kind of new LUK clutch, runs great, starts great, it is great. The truck is getting old.
I'm with Bob on this one, dig around until all possible causes are exhausted before doing the head(s). Keep us up to date as to what you find it may tweek someone's memory reading your posted info...
Really not rocket science but there is a different tone of each valve when the stem is tapped with a hammer and it reseats, due to one being bigger than the other do two exhaust valves ie 6 and 8 then the two intake valves. The valves should sound the same ie both intakes, then both exhausts. If you get one set with a different sound of the same type valve that could isolate the problem a little.
