Compression ratios - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 12-23-2007, 05:00 PM Thread Starter
Compression ratios
Ok, i know im reading way into this truck but i like to know as much as possible, but ive said that before.
What is the compression ratio on a 89 7.3 idi n/a motor, what is the compression ratio on a 93 7.3 idi turbo motor.
Im willing to bet theyre different.
Will
zukinut is offline
post #2 of 10 (permalink) Old 12-23-2007, 06:22 PM
7.3L F-250's Avatar
My Photos: (16)
Send a message via AIM to 7.3L F-250
Re: Compression ratios
i belive there both 17:1 compression
the least amount of compression for a diesel is aproximatly 16:1
company trucks
2002 ford F-350 powerstroke cc sb zf-6
1987 ford F-350 6.9L idi flat bed
1989 ford F-350 7.3L idi pick up
CURRENT PROJECTS
1978 ford F-350 custom
7.3L F-250 is offline
post #3 of 10 (permalink) Old 12-23-2007, 06:31 PM
91diesel's Avatar
17:1 is for a powerstroke.
I am 90% certain the older one is 21.5 to 1 as well for the 93......at idle that is. With the turbo, you could possibly get 30:1 I think probably more.
They are essentially the same engine if its a pre-powerstroke.
91diesel is offline
post #4 of 10 (permalink) Old 12-23-2007, 06:48 PM
Both N/A IDI and Turbo IDI share the same compession ratio 21.5:1
92_93 superduty is offline
post #5 of 10 (permalink) Old 12-23-2007, 07:04 PM
88beast's Avatar
yes 21.5 to 1
the psd is less and a turbo will increase it only when the engine is pulling load
88 f250 96 bed 95 front clip western mirrors and big ole bumper.
7.3 idi t70, 3g, g31,
other mods, oba, warn winch, big steel goodies including a headache rack etc.
check out my site at
88beast is offline
post #6 of 10 (permalink) Old 12-23-2007, 07:12 PM
PSD is less, turbo does not change compression ratio. It increase cylinder pressure on compression stroke. More air in same space.
post #7 of 10 (permalink) Old 12-23-2007, 08:54 PM
91diesel's Avatar
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: J_Wagner</div><div class="ubbcode-body">PSD is less, turbo does not change compression ratio. It increase cylinder pressure on compression stroke. More air in same space. </div></div>
HAHA! you are right!! i dont know what i was thinking. the valves are closed when it compresses so it doesnt make a difference.
My bad lol
91diesel is offline
post #8 of 10 (permalink) Old 12-23-2007, 10:11 PM Thread Starter
Thanks for the help. I was just figuring the later model turbo trucks might have lower compression due to the factory turbo.
Thanks again
Will
zukinut is offline
post #9 of 10 (permalink) Old 12-24-2007, 03:17 PM
7.3L F-250's Avatar
My Photos: (16)
oops my bad i read the artical wrong
sorry for the false info
company trucks
CURRENT PROJECTS
post #10 of 10 (permalink) Old 12-24-2007, 04:59 PM Thread Starter
No worries man, i appreciate any and all info i get.
Will
zukinut is offline
