Old 10-11-2005, 08:50 PM   #1 (permalink)
Compression test, what do I need?
I have the opportunity to do a compression test on my truck next week.
What do I need to know? I'd like to know the procedure for the test, and how to analyze my results.
I think the adapter set is snap-on. Does anyone know which adapter I need?
BTW, it is a diesel compression tester, goes up to 800 psi.
Thanks,
Brock
1986 F250 4X4 ext. cab w/1990 7.3L IDI and ZF5. 210,000 miles (I think and hope) and counting.
1986 F250 4x4 turbo diesel (doesn't run, parts truck, $400)
1996 Dodge caravan, free, 235K, and a bad engine.
And my parents 1993 F150: 5.0L, automatic, 2wd that I drive because I can't drive mine.
Click to see The Wonder Truck. Titled so by those who are in awe of its massive powers and adapted by those who can't figure out why it still works.
farmerbrock is offline
Old 10-11-2005, 09:12 PM   #2 (permalink)
My Photos: (24)
Re: Compression test, what do I need?
800 should be just fine, mine goes up to 1000 but it never got there. Procedure?
You can do one cicle depress, then 1 to 5 cicles depress. Allways check the reading right away. The reason I said 1 then 1-5 is you get the reading from 1 stroke and then you let it buil up but the first one not allways is the same since you dont know where the piston is at on that cylinder. Do it several times on each cylinder to make sure it is accurate, have a couple of good batteries for the test.
my 2c.
- 12/92 f350 jasper 7.3L 17k Torito
- Home made exekiel propane system, sweet
- Home made ram-air system
- 4.10 open, DRW
- zf5 trans (dextron and militec); 12" luk solid fly wheel and clutch set.
- exekiel coolant filter system (Fleet-guard filter and dca)
- ip runing with stanadyne every tank and Mels timed.
- Agnem manual tranns starting system :-)
- Hypermax turbocharger system YES Finally. Turned up a la Travis.
crew cab/ wood interiors/ 800w cd player. Sweet ;-)
2 new diamond headlights
4 100w flash lights and 2 withe fog lights
more pics
BOOB Man
soon..
- paint job.
exekiel69 is offline
Old 10-11-2005, 09:48 PM   #3 (permalink)
Okay, I suspect that I need to disconnect the fuel shut off solenoid so it won't start, and do I take out all the glow plugs first, or just one at a time?
Thanks,
Brock
Old 10-11-2005, 10:20 PM   #4 (permalink)
Brock,
Yes, do remove all of the glow plugs before starting the test. You do need to remove the plug from the fuel shutoff solenoid. The FSS wire on my truck is Red w/ Light Green stripe. I don't know if the wire is similar to your year truck. Good luck, Tim
'94 F250, 4X4, 7.3, E40D, 4.10, 126K
tim94f250 is offline
