Old 03-15-2006, 03:28 PM   #1 (permalink)
My Photos: (20)
Which configuration would be more sellable? 6sp or auto?
Well, I had posted a couple of months ago that I was thinking about selling my '91 to fund the purchase of something with a crew cab now that we have to have room for a car seat. Looks like I'm about ready to do that now, but I am in a bit of a dilemma.
I am getting a '99 CC dually that has 290,000 miles on it from the company I work for. Most of that mileage is on interstates and none of it in salt / snow, so it really doen't show the miles at all. Engine is good but could use an injector freshening. The problem with the truck is the current tranny. It's got a 6 speed in it that needs 3 synchros in the least, and since it's been rebuilt 5 times by dealerships I don't care much to keep it in the truck. The company always insisted on Ford clutches not LUK replacements, and poor clutch and pilot bearing design are responsible for most of the tranny rebuilds. Idiot drivers are responsible for the current lack of synchros.
Ok, getting to my point. The 6 speed in my '91 was brand spankin new about 20,000 miles ago. Not reman, new. I have no doubts about whether or not it was properly put back together after a rebuild... So, the obvious choice is to swap trannies. But, that leaves me trying to sell the '91 with no synchros. A reman is about $2000 or more, so that's not worht it for a truck I'm trying to sell. I don't really want the reman in the '99.
I still have the E4OD, driveshaft, and even stock rear end and wheels for my '91. That would make it back into a fairly normal F250 with the exception of the turbo and intercooler. Oh, and I would use the Baumannator TCS to run the tranny. It's a lot of work, but I am better able to spend time on it than cash! This might also take away some people's previously mentioned concerns of the amount of modification I've done on my truck and how that would affect resale.
So, what do y'all think? What would be the easiest (and most valuable) way to sell it???
Thanks,
Jason
Early 99 F350 CC Dually 6 speed - just acquired with only 290,000 on the odometer... Build date of 11/98.
'91 F250 standard cab, 3 E4OD's in first 100k, Hypermax turbo, 99 powerstroke intercooler, 6 yes 6 speed ZF tranny installed at 100k miles!!, '99 E-350 ambulance disc brake, limited slip, 4.10 rear end
1983 Ford Ranger Diesel - 2.2l Mazda engine, custom built 5 speed using RX-7 parts, custom built ex manifold to add a variable nozzle turbo off a Mercedes, homebuilt 2 tank WVO system
1946 Dodge COE 1.5 ton in process of restoring and repowering with Detroit 4-53 turbo and Road Ranger 610.
My shop
jaybee is offline
Old 03-15-2006, 06:15 PM   #2 (permalink)
Re: Which configuration would be more sellable? 6sp or auto?
Hmmm. That's a tough one.
Two options. Install the auto back in the old truck, and sell the bad 6 speed as a core.
Or install the bad 6 speed in the old truck (less labor) and sell the automatic with the truck or seperately. A good E4OD should be worth $900 - $1200.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 03-16-2006, 12:01 AM   #3 (permalink)
3rd option
When I had my tranny rebuilt at a medium/heavy truck transmission shop, they mentioned a fix for the six speed.
The problem is, in their opinion, the 13" clutch is way to heavy for either the small pilot bushing or bearing, I can't remember which the 6sp has. What they do is send the flywheel over to a machine shop where it is machined to take a much larger roller bearing, able to take the weight. It's an additional $150. I was just glad to tell them I had a 5 sp and no need for all that work!
Good luck
A.K.A. Sign_man
1988 F-Superduty bucket truck, 7.3 IDI, LuK Clutch, 5 spd, 4.10 rear
http://photos.thedieselstop.com/show...=70062&thumb=1
Phillipmc1268 is offline
Old 03-16-2006, 12:34 AM   #4 (permalink)
My Photos: (17)
I think the 91 would be more sellable with the E4OD and TCS. If you do go that way, PM me and I could send you the program variables that I've got worked out with the TCS. It takes a while to "fine tune" the program and I'm still fine tuning my downshift functions. OkieG
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 03-16-2006, 03:24 AM   #5 (permalink)
My Photos: (33)
Jason, the auto trans is much more sellable to John Q Homeowner then the standard.
I might be interested in that worn out 6 speed.
95" Extd Cab F250HD 4x4 DRW, /86"6.9 T19 GV o/d 3.73 axles, Hypermax Pulse turbo, intercooled / Modified Hypermax ram air induction, PowerShot 2000 LPG system "first design". Ride rites @ all 4 corners, Dana 50 mono Beam up front, Ford 10.5" in rear with 4 wheel disk brakes. Other Truck, 1983 IHC "S" with 14ton NoMar wrecker body, 30,000 GVW, 229"wb with a 6.9L IDI, Clark 5sp, 5.57 rinp&pinion, turbo charged and intercooled (with LPG soon).
Huff is offline
Old 03-16-2006, 02:21 PM   #6 (permalink)
OK, I'll post back on this.
Here's what I think.
Put the good zf6 in the newer truck. You'll save about 2k right there. Then, put a older manual tranny in the 91. You already converted it to manual. As far as the axle - it's up to you.
If you were closer, I'd trade you a good tranny and axle for your junk trans and your axle. I love what you did, and want to do it to my truck. I just don't think it'll raise the resale value of my truck when I do it.
This tranny swap will save you about $1500 total. I think it's a good investment.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
mgraveman is offline
Old 03-16-2006, 03:19 PM   #7 (permalink)
If the '91 is in good to top shape every where but the tranny, then the auto would be best and charge top dollar. If the rest of the pickup is in poor condition except motor, throw the old standard in and sell as parts truck and sell auto tranny with controller seperate.
'91 F250 SuperCab 4X4 Stock IDI 2 tone brown E4OD
'88 F350 Crew SRW (now parts)
'97 Aerostar 4X4 Extended 4.0
'93 Sable 3.8
'92 Taures 3.0 sold
'84 Bronco II 2.8 4 speed 4X4
'84 Ranger 2.8 2X4
'50 F-1 V8 Flathead 4-speed non syncro(bought new)
'76 Honda 250 Multi Sport(enduro)
mont91 is offline
