Re: considering 93 Ford F350 4x4 diesel
I dont have a ton of expirience with the 7.3 IDI but i can share with you a little. My neighbor has a '93 7.3 IDI F-250 converted dually. Its got 275,000 miles on it and it runs like a top. The only things he has done to it are a rebuilt tranny (E4OD), a set up Glow Plugs, and a Glow Plug Relay.
First and foremost I would want to test drive the truck in ALL conditions (First thing cold in the morning, Fwy Speed, around town) give it the full range of driving because some problems can be found only under certain conditions. Look for things like excessive smoke, especially white/blue smoke when the motor is warm.
1997 F-250HD SuperCab●4x4●ZF-5●4.10●Tymar Intake●Tymar HPX●Wildman 3 Pos. Chip (Econo/Tow/Xtreme)●SD Intercooler●17* HPOP●4” Straight Pipe w/5” Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●LuK SMFW●4” Rancho Suspension Lift●Ride Rite Rear Bags●Bilstein 5100 Shocks●Rancho Stabalizer●Energy Poly Bushings●Hella 550’s●Line-X●315/75/R16 BFG A/T●Pro Comp XTreme Wheels●Diamond Plate Rails, Gate, & Bulkhead●Ford AIC ●Cobra 25 w/ Wilson 1000 Ant. & RK-56 Mic●Sirius Sat. Radio●
