Old 03-31-2006, 07:14 PM   #1 (permalink)
Powerstrokedogg's Avatar
Send a message via ICQ to Powerstrokedogg
coolant filter questions
i would like to put a coolant filter on my truck, i was wondering where do i hook it up at, i was thinking just splice it in between my heater core and the block [img]/ubbthreads/images/graemlins/shrug.gif[/img]
second i want to use a filter with the sca additive already in it, i have been looking at wix filters. is this compatable with my ford diesel coolant additive?
thanks
2001 F-350 7.3L 4X4(ESOF) CC LWB 4R100 4X4, WIX 46637 open element air filter, Wicked Wheel, walker BTM, 203* Tstat, IC tube foil removed, coolant filter, AIH removed, 08 aluminum finned rear end cover, DP tuner 80econ 140smoke high idle,Phantom gauges, ATS transmission,ATS deep trans pan, 5 star torque converter, V10 trans cooler, 4" MRBP SS downpipe, twin 4" stacks
1989 F-250 6.9L IDI E4OD 500,000+ miles(sold)
1982 VW rabbit 1.6L diesel
Powerstrokedogg is offline
Old 03-31-2006, 09:02 PM   #2 (permalink)
My Photos: (17)
Re: coolant filter questions
You DO NOT want to just splice it into the heater hose. You use 2 tees to install the filter BETWEEN the two heat hoses. Get 2 small ball valves to shut off the coolant to make changing filter much less messy. The filter restricts too much coolant flow and if it installed inline it would take forever to get any heat out of the heater in the winter. Coolant passing by the tee on the trip from the heater core will draw a relatively small amt of coolant from the line going to the heater core. It takes lotsa "by-passes" to filter the coolant but it does work. Just like a by-pass oil filter does. The "pre-charge" in the filters is a biscuit and it disolves over time. It usually is the kind of SCA that Ford uses. OkieG
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 03-31-2006, 09:11 PM   #3 (permalink)
You need a filter head, filter, 2 "T,s", 2 valves, threaded fittings, hose barbs, clamps and hose. "T" into the inlet and outlet of the heater (reason being for the 2 T's is that if the filter plugs up you will still have flow - so no over heating issues) Valves are for when you change the filter, min loss of coolant. I use fleet guard filters (and head) with their coolant. Flush the system (donot forget the block drains and the heater. Fill with precharged antifreeze and distilled water. Use just a plain filter (no sca's) for the firs few months then change to a pre - charged once you need to adjust your ph and nitrates. Every now and again (scientific term for when you remember) feel your filter and make sure it is as hot as the hoses to make sure it has flow. Hope this helps
deanj is offline
Old 04-01-2006, 06:20 AM   #4 (permalink)
cdnsarguy's Avatar
My Photos: (66)
This company makes the kits applicable to PSD installation we asked them to make one for us but declined. I'm pretty sure we could adapt it fo a location suitable. Click web page
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 04-01-2006, 07:38 AM   #5 (permalink)
thanks for the help
putting in 2 Ts between the heater hoses was my second idea, i will hopefully plumb it in today
the kit i got(filter head) is a wix 24019
thanks again [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
Old 04-01-2006, 08:30 PM   #6 (permalink)
well it was a slow day at work so i had plenty of time to install the filter, the hardest part was finding a good location for it [img]/ubbthreads/images/graemlins/phoney.gif[/img] i ended up mounting it to the bottom of the fan shroud
after alot of thinking and talking with the other mechanic i ended up putting a T in the heater hose coming out of the head,then routing it to the inlet on my filter head. for the return i pulled the plug out of the top of the water pump and added a heater hose fitting
i have great flow to my filter and my heater core, both of them are HOT [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
right now i have the WIX 24070(additive free) filter, then when i replace it i will be using the 24071 additive filter
Old 04-02-2006, 01:31 PM   #7 (permalink)
Gibson's Avatar
your new filter will not last the 3 months or 50K miles repalcement interval. after 1-2K miles it will be time for another new filter. reason being is that the coolant has never been filtered and will collect an enormace amount of gunk on the first time. my truck is on its 2nd filter only after 1000 miles. and when i hit 2K i will change it again. the 1st filter was filled with a paste! thats even after i flushed my motor/radiator 5 times and aput in brand new coolant and distilled water..........Gibson
D.T.Gibson
1.830.203.1460
new newer rig: '05 greyish/balckish Ford F-350 XLT Lariat, Crew Cab, 6.0L PowerStroke, Fx4, Leather and all the electric goodies besides a moon roof, auto trans, 3:73's, leveling kit. SCT Looney Tune stacked with Edge Juice with Attitude, and 4" turbo back exhaust. 91K.... blew HPOP and headgaskets. In shop for now. maybe by the 8th ill have her back with new long block! sweet!
newer rig: late '99 Red Ford F-350 PowerStroke, 4x4, CC, 4r100 Auto Trans, 3:73's, Stage Coach Conversion, 4" DP to 5" up to 6" stack, aFe Stage II intake, DP Tuner 4pos chip, dFUSER oil crossover line, 10K mod, AIC controller, '06 18" King Ranch Wheels. 225K.
new rig: CUMMINS POWERED '95 F-350 XLT, crew cab, Blue & white, ZF5-speed, 4x4 with auto locking hubs, 4:10 gears, 283K miles, 3" DP to 5" exhaust, Auto Meter A-pillar 3-gauge pod with EGT, Water temp and oil pressure.
Gibson is offline
