hey guy's you might wont to check out this filters i don't have any of this cause i got the one with out the cda's.
- 12/92 f350 jasper 7.3L 17k Torito
- Home made exekiel propane system, sweet
- Home made ram-air system
- 4.10 open, DRW
- zf5 trans (dextron and militec); 12" luk solid fly wheel and clutch set.
- exekiel coolant filter system (Fleet-guard filter and dca)
- ip runing with stanadyne every tank and Mels timed.
- Agnem manual tranns starting system :-)
- Hypermax turbocharger system YES Finally. Turned up a la Travis.
crew cab/ wood interiors/ 800w cd player. Sweet ;-)
2 new diamond headlights
4 100w flash lights and 2 withe fog lights more pics BOOB Man
11 units is too much - will over treat the system. Remember we have a small cooling system (in the grand scheme of things). Max you want to use is 8 units, 4 units will work but will not keep the level towards the max concentration point (not a problem), 2 units will require that you use some bottled DCA to say in the 'green' if you will.
Travis
Will Work For Diesel Fuel.
ok, i tought it was a very good deal since they are fleetguard and somebody could use it. i readed they are 11 units just didn't know how much was too much
exekiel
- 4.10 open, DRW
Not a problem just didn't want any newbies running out and creating more problems for themselves. See this is how we ALL learn... [img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Travis
- 4.10 open, DRW
While we're on the subject of coolant filters....I had the hood open today and noticed that I plumbed it in with one side of filter into the heater hose going into the heater core and the other side of filter into the hose coming out of heater core [img]/ubbthreads/images/graemlins/shrug.gif[/img]. Why? Why not just parallel to one of the hoses. I know why not to hook it directly into the hose in series, it restricts the coolant flow enough to slow the heater output on the cold Baja nights. I'm just wondering if I'm having a 'Senior Moment'/C.R.S./Brain-Fart [img]/ubbthreads/images/graemlins/shrug.gif[/img]. [img]/ubbthreads/images/graemlins/smokin.gif[/img]Baja
provably wont affect the heat on the heater core but it could slow down the flow as you said and provably create too much pressure on the hoses or delay the flow to wpump and posterior to the radiator and then your engine could over heat.
don't know, just an idea.
exekiel
- 4.10 open, DRW
Sorry Baja, but there is a problem with your puttuing it in series with the heater. When you have the heater OFF you will not get any flow. I was thinking along those some lines when it occurred to me. [img]/ubbthreads/images/graemlins/bleh.gif[/img] CRS? yes.
Dave [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
2004 F-350. Standard Cab, 4X4, 6.0 with Torqshift, 3.73 w/LS. <font color="red">(((XM))) Satellite Radio.</font> Lo Jack, 6608 lbs wet. Born on 8/4/2003. Engine 07/23/2003. 3" Lift. Grover Air Horns!!! http://community.webshots.com/album/85108545NlXNsD
1993 F-350 4X4 7.3 IDI with 5 spd. Gone now.
1976 Kenworth C-500 with Detroit Diesel 8V92TA with 3 spd Jake, SQHD's and RTO 12513 10 Wheel Dump Truck. Sold.
Hi. Now I could possibly be mistaken, but as far as I know the heater core runs wild on all the IDI trucks (full flow all the time). The heat control is an air flow door. Brad
1994 F250 SC, long box 4WD, 7.3 factory turbo,E4OD, 3.55 Axle,185,000Mi, hope to do some mods soon, just bought Feb 05. 1987 F350 Crew Cab, 2wd, SRW, L box, 7.3, 5spd (some PO put them in), 3.55 Axle, 184,000Mi or more, not a pretty truck, usually pulls 5th wheel flatbed, air cleaner mod. 1987 GMC Suburban, 2wd, 6.2, 700R4, 188,00Mi, getting rusty, run around truck. 5020 John Deere 531 cu in, The Big Toy, soon to have a heavy duty loader mounted. Plus to many more Fords, JD's and other toys. REAL TRUCKS DON'T HAVE SPARK PLUGS !!!
yep no flow control on the heater cores unless you have added one (which is quite the popular mod).
Baja,
I would expect that there is some pressure difference between the heater core sides (input vs. output) and with installing the heater core in parallel with only one hose that you would have no pressure difference so theorically no flow would happen within the filter. That is why you installed it between BOTH hoses...
now for those that wonder why to not install it in just one hose (series with Heater core) is because the coolant filter cannot handle that much flow and will restrict the flow down to a trickle and you will freeze you coogies off in the winter if you live where there is that white stuff for half the year.
Being that Baja is in Mexico where they say "snow - what the heck is that" it would not be a problem but come north just once when the temps are low and you'll be playing in coolant on the side of the road changing it's flow pattern and wishing you plumbed it differently to begin with... [img]/ubbthreads/images/graemlins/wink.gif[/img]
Travis
Whew..thanks guys, I must be having 'A Senior Moment'. What with trying to get things fixed/finished around here so that we can sell this place and move back to 'The Real World-U.S.A.', the pressure/stress is getting to me. And, after all, that is ONE of the reasons that the V.A. pays me sooooo much [img]/ubbthreads/images/graemlins/shrug.gif[/img]. [img]/ubbthreads/images/graemlins/smokin.gif[/img] Baja
