Re: coolant in oil-what besides cavitation?
I disagree, I believe cavitation is the least likely cause. Your possibilities in the order of likelihood are: 1, oil cooler seal leak 2, head gasket leak 3, cavitation low in the cylinder (cavitation high would cause coollant burning / hydrolock).
I'll probably get flamed for this, so be it. Buy 2 bottles of Bar's (pelletized) stop leak, dump it in and change the oil and see if that stops the leak. If not, THEN start tearing things apart.
*ASE Master Certified, Medium & Heavy Trucks*
