Old 02-26-2006, 01:39 PM   #1 (permalink)
coolant ph and nitrate levels?
well i bought a coolant test by wixs and the freeze and ph level was fine in the right zone, but the nitrate level was a 0? and i read that you can not mix different treaments so what am i to do ?
1994 f250 super duty ext. cab 7.3l IDI turbo. 4x4 manual tranny. I am new to the diesel trucks, i bought this truck to pull my tractor and equipment for my landscaping business
ncfirefighter46 is offline
Old 02-26-2006, 02:24 PM   #2 (permalink)
Re: coolant ph and nitrate levels?
I'm not sure what you read but you should get some SCA (Wix brand is fine) and pour it in. This bulletin should be interesting to anyone concerned about mixing stuff.
444-4D is offline
Old 02-26-2006, 03:15 PM   #3 (permalink)
My Photos: (17)
Thanks for that link. Great info to a long debate. However, I don't think NAPA test strips work for the FW-16/VC-8 type of SCA. Only for the PennCool or NapaCool type in FleetCharge or Prestone Heavy Duty purple colored A/F. There may be other mfgs ofthe purple coloer stuff, I just haven't found out which. OkieGringo
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 02-26-2006, 05:46 PM   #4 (permalink)
so other words all that hype about different coolant additives are just hype then? i can just buy some and add it and get the levels right, i dont know how long this truck has been this way either, i bought it needing to fix a knockng clutch, and i am redoning a lot of it. fixing rust and fixed the clutch, i do know it seem to run fine when i bought it.
Old 02-26-2006, 06:42 PM   #5 (permalink)
Mostly hype yes. Just be aware that DCA-4 uses Nitrite and Molybdate. If you use this type of SCA you will need to use a test strip that checks for both because you have to add the two together to get the total SCA level.
444-4D is offline
Old 02-26-2006, 06:43 PM   #6 (permalink)
My Photos: (17)
Well, what it means to me is, I won't worry quite so much about draining the block so completely if/when I change the coolant out. If most is NapaCool type, a little of the Ford/IH type won't hurt. Test strips for the different types, test for different chemicals. I'm gonna stay with the NapaCool stuff as the test strips are much easier to get. [img]/ubbthreads/images/graemlins/shrug.gif[/img] OkieGringo
Old 02-26-2006, 08:39 PM   #7 (permalink)
Are you buying the 50 pack for $35+/-? I've called two NAPA's and that is all they have. I'm under the impression I'll be wasting a chunk of dough. Don't those strips expire?
If you're not getting the 50 pack, what part number are you getting?
Thanks,
Devo
Work like there is a tomorrow and play like there isn't.
87 F250 Lariat SC LB 4X4 with an NA 6.9, C6 and 4.10's. Dana 50 IFS up front. 244K mi. 3" exhaust, WVO, Ram air. Thinking about propane or methanol/ water...
First diesel and a lot to learn....
96 F350 CC LB 4X4 AT 231K
Second diesel and still a lot to learn...
DevoK12RS is offline
Old 02-26-2006, 08:48 PM   #8 (permalink)
My Photos: (17)
Thanks,
Devo
Actually, I haven't bought any Napa test strips yet. I haven't had the PenCool/NapaCool type A/F in the engine long enough to worry about depleteing the sca. But I'll check at my local Napa store and let ya know. But the FleetGuard test strips DO expire, but they are usually available in packs of 4. OkieGringo
Old 02-27-2006, 07:17 AM   #9 (permalink)
i bought the wixs set from orielly's and it is the kit for 25.00 and they where alot cheaper then napa.
Old 02-28-2006, 11:32 AM   #10 (permalink)
Question. If we are testing nitrate and ph, cant we just use pool test strips. As long as we know what levels they need to be at it should be ok??? Right. Pool test strips are only like 10 for 50 at lowes. If it will work what are the right levels for ph and nitrate values.
Sold it!!! 1993 F350 rebuilt 7.3IDI Turbo Crewcab running 4.10 and 35x12.50x16. Who needs mufflers... straight pipin' with banks downpipe upgrade and 3 in exhaust all the way back and gettin 18mpg if my foot wan't so dang heavy. Biodiesel home brewer and convertion to WVO almost ready for install. Electric Facet fuel pump conversion.
2006 Dodge 2500 Megacab Cummins...stock...for now..hehehe
ak_cowboy is offline
Old 02-28-2006, 12:36 PM   #11 (permalink)
I don't know about pool strips but I think the best strips to use are Fleetguard 2602 and 2607 strips. You should use both kinds of strips. They can usually be purchased as singles at HD truck shops. 2602 strips test for Molybdate, Nitrite, and Freeze Protection. 2607 strips test for PH, Chloride, and Sulphate. There are probably other brands but those are easy for me to find locally.
444-4D is offline
