Cruise Control not working - Diesel Forum - TheDieselStop.com
Old 11-15-2009, 01:40 AM   #1 (permalink)
flatbed73's Avatar
93 7.3 XLT crewcab dually
ok, Ive checked(all fuses are good) everything I can think of having to do with my cruise control not working(does not turn on at all) I noticed when i got the truck, that they replaced the brake booster, There is a plug on the top of of it but nothing is running to it. I assume this deals with turning the cruise off when you hit the brakes. Seems that the plug I have for the brake booster does not work with it. Im guessing my cruise wont turn on because it isnt wired up to the Brake booster. Anyone have any insight to this situation?
1993 F-350 Super Cab 7.3 IDI (non-turbo) Dually, self built custom flat bed. Have pics soon!
flatbed73 is offline
Old 11-15-2009, 10:50 AM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Could be a fuse..... check cab and under the hood boxes. under hood (C or #3) is the horn and cruise main fuse, there is also one in the cab box a 20 amp yellow #6. PM me Your email and I will forward the Cruise manual to you if you still need it.
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 11-15-2009, 02:14 PM   #3 (permalink)
Beazer's Avatar
i have checked all my stuff as well, i just need to know where the under hood fuses are in a 89
Beazer is offline
Old 11-16-2009, 08:08 PM   #4 (permalink)
3/4tonman's Avatar
Send a message via AIM to 3/4tonman
Your 89 doesn't have underhood fuses.
  1. 1971 F250 Camper Special 390, c6 auto, 4x2, 63k original miles, rebuilt engine. It's had a hard life.
  2. 1984 F250 6.9 IDI, 4-speed manual, 4x4. Rolled so now its a project.
  3. 1985 F250 351W, C6 auto, 4x4. Dads truck.
  4. 1988 F250 7.3 IDI, C6 auto, 4x4. Bought it with new heads and rebuilt injection pump. Since then new parts include ball joints, brakes and brake components at all wheels including parking brake cables, fuel sending unit, injector return kit, belts, starter, batteries, and alternator. Sno-way 9'1'' v blade. Ready to make some money!
3/4tonman is offline
Old 11-18-2009, 03:58 PM   #5 (permalink)
could be the vacuum is disconnected from the servo? could also be the speed sensor, i believe you have 2 seperate ones the one with the cable is the one for the speedo and the one on the tailshaft is for the e40d and cruise. if your tranny is shifting ok(being its the e40d) then its prob not the speed sensor. its usually the horn fuse or the switches in the steering wheel.
1989 f-350 crew cab 4x4 7.3l 5-speed
subliminal is offline
Old 11-18-2009, 07:55 PM   #6 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Flat bed....93 if you want the cruise manual PM me your email addy.
Beazer what year truck??.... vacuum operated S/C below.
Ziggster's page
Old 11-19-2009, 07:07 AM   #7 (permalink)
flatbed73's Avatar
Thanks guys, I think that got me going in the right direction! You guys are awesome, I appreciate the help!
Old 11-19-2009, 11:28 PM   #8 (permalink)
My cruise was not working and a retired Norfolk Ford plant employee told me to check the vacuum. I pulled one of the other lines temporarily and hooked the cruise hose up and it worked. He said there is a plastic canister that can crack and lose the vacuum so I have to check that out now.
Wakawaka 'cause that's what it sounds like
1991 E350 7.3 IDI E4OD
1986 E350 6.9 C6 dually box
wakawaka is offline
