Deep Cycle Batteries - Page 2 - Diesel Forum - TheDieselStop.com
post #16 of 28 (permalink) Old 11-11-2012, 02:11 PM
bluefishbeagle's Avatar
If you want lots of cranking power go to two 14 volt race car batteries. I thought about it but have not yet since my batteries are in good shape. It would require changing the charging rate to about 16 volts. There are kit to do that. Electrionics should be OK but light filament might not last as long especially with a lot of vibration.
1993 F250 7.3IDI Turbo (factory) 2X4 ZF5 4.10 Diff, Floating axle, Extended Cab Long Bed ZeeDee running boards, 185K miles, Second Owner
1999 Victory V92C Overdrive Sprocket, Power Commander, High Compression Pistons, Performance cam. Slash Cut pipes, Corbin Seat, Factory windscreen, Highway bars.
*Commercial pilot and certified aircraft mechanic by choice, Ford mechanic by necessity*
Most iconic aircraft ever built? Ford Tri-Motor of course!! Take a virtual tour
bluefishbeagle is offline
post #17 of 28 (permalink) Old 11-11-2012, 02:25 PM
You can go here Deep Cycle Battery FAQ and get a lot of good information. I use Trojan T105 6 volts in series for a battery backup on my house and 2 of them in series for 12 volt power in my rv. They perform just like they are rated. If you decide to use deep cycle I too would encourage you to go with a name brand. I know Trojan, U. S. Battery to name two are excellent batteries to go with. I think what you would find more useful to start the truck would be two heavy duty 12 volts. Good luck
94 F350 Dually 2wd,4:10,E40D,R&D pump, sticks, and 3"turbo downpipes,Dynomax 3" exhaust,Gear vendors, 24000 trans cooler,
Johnnybgood is offline
post #18 of 28 (permalink) Old 11-12-2012, 09:57 AM
re: "You can go here Deep Cycle Battery FAQ and get a lot of good information." -- that is a good resource and also a good example of why you need to read information presented on the web very carefully.
For instance, that NAWS FAQ tells you that the 'deep cycle thick plates' idea is a myth if you actually consider the numbers it provides for plate thickness (as contrasted to its also repeating the myth anyway!). The description of battery life is also interesting as it provides some indication of the lack of precision in this measure with such factors as voltage or brand being near meaningless. There is also an RV battery page on that site that is very good.
Upping the voltage a bit is one way to push a bit more power through the starting circuit. That can be handy for the cylinder heaters, too. Care is needed to avoid too much for too long.
It is interesting that the 'deep cycle battery' thing keeps going oblivious the idea that there is no objective measure for it or specification that can be used to delineate it. This phenomena well illustrates that empirical reasoning often succumbs to myth and emotion. caveat emptor.
bryanl is offline
post #19 of 28 (permalink) Old 11-14-2012, 03:15 PM
I bought 85 diesel in 1992 with Delco marine rv continous use deep cycle batteries ,after 12yrs i decided to replace even though they were still good,i bought 92 and went with same batteries.
mazama is offline
post #20 of 28 (permalink) Old 11-25-2012, 01:42 AM
Originally Posted by chuckster57 View Post
Optima red top is rated 800CCA at zero degrees.
Sent from my iPhone using Autoguide.com App
Red Top is not a deep cycle, Optima Yellow tops are starting deep cycles with the Blue tops being Marine/RV deep cycle.
Y'all can go back a forth with "facts" all you want.
I'll tell you from first hand experience. Years back when I knew I need to get away from water cell batteries, I called Optima to find out which batteries to run in my '96 diesel and was told that their Yellow tops were the deep cycle for starting and that they were what was needed for my truck. I ran them the first time around, then after that and talking with several Optima enthusiast I went to the Red tops and have been running them ever since.
The Red tops actually last as long as the Yellow tops in a diesel.
It's not a matter of deep cycle or not, it's a matter of QUALITY batteries.
I may have to check into the Delcos though.
1994 Ford E350 Uhaul 17' box 7.3 diesel / auto 184k+ miles
2003 Chevy 2500HD Ex Cab D/A w/ 260k+ miles, Line X sprayed bedliner, 36 gal transfer tank, air foil, B&W Turnover w/ Fiver adp (bought new)
Sold 1996 GMC 2500HD Ex Cab 6.5 TD w/ 343k+ miles, 3000lb adjustable overload springs, Ultimate sprayed bedliner (bought new)
K&N air filters & Optima batts in all and Prolong in the oil & trannys
Previously owned 1994 Chevy 2500HD Ex Cab 6.5TD, put over 120k on it
Semper Fi Overcome & adapt
been everywhere is offline
post #21 of 28 (permalink) Old 11-25-2012, 11:09 AM
My Photos: (27)
I would think so. I don't see the need for the Yellow tops since you're not really discharging the batteries that much because of glowplugs and starting. I had two Red tops previously and they lasted over 7 years. After 7 years they were still going strong but I felt I was pushing my luck so I replaced them.
LMJD is offline
post #22 of 28 (permalink) Old 11-25-2012, 03:49 PM
bucketeer's Avatar
I see a lot of great information about batteries on this thread but some of it is at odds with what I have researched when I went through the agony of finding what I needed.
I selected a pair of 1050 cca Sears Platinum batteries for my engine starting and another pair for the DC motor over hydraulic for the aerial lift in my work truck.
These batteries are reported to be manufactured by Odyssey who uses this same technology for military vehicles. I'll drop the link and let you read for yourselves but believe these new batteries are not you fathers old Exide's.
Whole new technology, chemistry and charging requirements. I wondered why I was getting reports of deep cycle batts. failing after a year or so. Found out folks were trying to charge them with a 6 amp charger. They require a diet of >40 amps and will recharge in less than an hour.
The batts. I chose are both suitable for starting and high current deep cycle and may be combined to charge from the same alternator or charger as they are all the same.
They have thinner "pure lead" plates so there is more natural capacity.
Observation: Spiral reports are very negative unless they have made recent changes.
Do your research before you buy anything. New battery technology is coming daily.
Best of Luck,
Link for information only.
ODYSSEY Batteries - Official Manufacturer's Site
1991 Ford F SD Bucket truck W 7.3L IDI
Equipped with TEL-29-EBA Versalift.
with (2) 1050 cca deep cycle batt. emerg backup.
5 KW Dynamote 110/220 AC converter
125PSI Gast air compressor
600W DC/AC sine wave converter
Custom shelf workspace w/ DC / PC and 17in monitor
Custom dash brow instrument panel
Bucket seat (pass side removed for cargo space)
bucketeer is offline
post #23 of 28 (permalink) Old 11-25-2012, 09:16 PM
Lifeline Batteries - Marine & RV Deep Cycle AGM Batteries < I'd trust thier data as they are well well knowen in the Off grid circles and the yating and comercial marine circles and the RV.
New truck: 1988 F-350 1 ton dualy 2*4, 7.3L IDI Naturally Aspirated, Dual tanks with Camper package.
Mods: Enhanced gauge cluster; Transmission temp, rear diff temp, coolant system pressure, Vacuum pressure, Fuel pressure, Crappy tire Air horn Kit, Raycor pre filter/water sep. All LED Dash lighting, Parker LFS tranny filter, super duty tranny cooler, gerret turbo, waste gated (pending).
Xeonpony is offline
post #24 of 28 (permalink) Old 11-26-2012, 08:48 AM
My Photos: (27)
That's what I got in place of my Red Tops. There was a guy on here who was not just parroting internet B.S. but was actually in the trade (automotive batteries) and he gave the reasons why the Sears Platinum (Odsseys) were the best out there, even better than Red Tops according to him. They cost a fortune and if weight means quality they got to be good.
LMJD is offline
post #25 of 28 (permalink) Old 11-27-2012, 12:39 AM
What did they cost? How long had they been available?
post #26 of 28 (permalink) Old 11-27-2012, 07:53 AM
My Photos: (27)
Can't remember what they cost without hunting through a bunch of receipts. I'm sure the price is easy to find on the Sears website. Without looking, mine are about 3 years old now.
LMJD is offline
post #27 of 28 (permalink) Old 11-27-2012, 09:39 AM
GoldwingElf's Avatar
Looks like they are about $200 each, they are AGM.
'02 F350 Dually
AIS, ZooDad and BTM
60 tow and 80 E DP tunes
Stealth Monitor
GoldwingElf is offline
post #28 of 28 (permalink) Old 11-28-2012, 08:41 AM
drinkypoo's Avatar
My Photos: (25)
wally world has 850s real cheap that start just fine... and have a great warranty. just sayin'
1997 Audi A8 Quattro 225k Warm/Cold packages
drinkypoo is offline
