Old 01-15-2007, 10:40 PM   #1 (permalink)
Diesel coversion Question
I am about to tackle a diesel conversion and needed a little info on trannys.
I have a new holland 1068 Bale wagon that is currently powered by a 460 gasser and a 4 speed manual. I want to convert to a 7.3 IDI and a auto tranny. I am very familar with the 7.3 as I have owened several of them and I know the electral is very simple. Now I have located a 92 F250 as a donor truck which has a low mile 7.3 and I am pretty sure a a E40D. Is this computer controlled and how dificult is it going to be to incorperate the computer and wiring into my Bale wagon or is the electrical fairly simple on the E40D? Any help or Ideas would be greatly appreaciated.
2006 F350 King Ranch
4.30 gears auto
BrianLusk is offline
Old 01-15-2007, 11:09 PM   #2 (permalink)
Squid63's Avatar
Send a message via AIM to Squid63
Re: Diesel coversion Question
For simplicity, I would stick with the 4 speed, a 5 speed, or try to find a C6 Automatic. Unfortunately, I can't really say how hard it is to wire an E4OD to stand alone, but someone may chime in. With a donor truck, and enough time, anything is possible though.
94 F250 Supercab 4x4, 7.3 IDI Turbo, NV4500 5 speed, 4.10s
95 F350 Crew Cab 4x2, 7.3 DI, ZF 5 speed, 3.55s
Squid63 is offline
Old 01-15-2007, 11:31 PM   #3 (permalink)
The shifting on the E4OD is done by the computer. Without the computer you have only 2nd and reverse.
The E4OD computer needs 4 sensors to work. 3 of them are on the motor and trans, the 4th (vehicle speed sensor) may be mounted either in the rear axle or the trans tailshaft.
Me, I would swap the E4OD for a good diesel C6. I'm afraid that the E4OD may give you fits in your ag equipment. Or else you could get a diesel bellhousing and bolt the motor up to your existing trans.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 01-16-2007, 05:26 AM   #4 (permalink)
thanks for the response, does painless wiring make any kits for the E40D?
I have not purchased the donor truck yet but at only $2000 with only 50000 on a rebuilt 7.3 I will be hard pressed to find a donor for that price. What year was a 7.3 availble with a c-6
4.30 gears auto
Old 01-16-2007, 12:29 PM   #5 (permalink)
Well the E4OD was introduced in 1989, so all years before that would have the C6. A trans from a 6.9 would have the same bolt pattern.
The wiring isn't the big thing with the E4OD, my concern is if you could get the computer to shift the trans where you wanted it to. The C6 is much simpler to adjust shift points, or you could even install a manual shift body and shift manually.
IMO, the E4OD is too complex to try to use in an off-spec application.
Old 01-16-2007, 03:24 PM   #6 (permalink)
I'd say stick with the granny 4-speed...that way you can engine brake if need be. Does the bailing wagon even travel at a speed in which you'd need OD?
89 F350 SRW, ZF 5, Boost by banks, 57 trim Kubota comp wheel, 5" straight pipe, manual hubs.
dsf79 is offline
Old 01-16-2007, 07:47 PM   #7 (permalink)
typefour's Avatar
Brian, where abouts are you, I have a c6 that I will never need, could go cheap. pm or whatever.
91 F350 crew cab 4x4 7.3 ats and intercooled with '04 ps cooler , ,coated rockers , balanced. very good power.
pyro,boost and all stock guages ignored with mechanical real ones
Fugitive sandrail. 2400 cc type4 engine, my baby
Invader sandrail, 1.8 jetta engine installing spinny thing soon.
83 300 sd ready to build a real hotrod engine for this one.
Misc. vw's scattered about.
typefour is offline
Old 01-16-2007, 10:47 PM   #8 (permalink)
since we are on the topic of conversions and trans. I am about to do a 7.3 idi conversion on my 250 i have a c6 trans can i put this 7.3 to my c6 without and mods to the trans without having overdrive will that ruin my top speed just a few question ihad might post a new topic any help would be nice
1994 F-350 4x4 XLT 5 Speed. DP Tuner 4 position stock, 60Tow, 100Race, 140Smoke. AFE Intake, 3.5 Downpipe into 6inch miter cut stacks. Intercooler from 99, Exhaust Brake, Boost and pyro magtec rear cover, train horns, 181000 and counting
hitechredneck350 is offline
Old 01-17-2007, 01:05 AM   #9 (permalink)
C6 gas, and a C6 diesel are two totally different transmissions. I couldn't bear the thought of not having an OD on the highway (unless I could make fuel for like .50 cents/gallon)
dsf79 is offline
Old 01-17-2007, 04:02 PM   #10 (permalink)
My Photos: (23)
The C6 is a great trans, but would have been even better with OD. The E40D is a trans that would have been better off being a 3 speed. [img]/ubbthreads/images/graemlins/tongue.gif[/img] Go manual or C6 for the bailer. We want pictures when it's done, AND I think you should put Dual Chrome stacks on it. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 01-17-2007, 08:30 PM   #11 (permalink)
6 INCH CHROME BULL HAULERS
1987 F350 4 Door 6.9IDI 5Spd Banks Turbo Dually -1986 F250 Reg Cab 6.9IDI 4spd 4X4 Dually-1988 F250 Reg Cab 7.3IDI C6-1985 F250 Ext Cab 7.6 DT466 10spd
http://community.webshots.com/user/MyDTpickup
INTERNATIONALDIESELPOWER
MyDTpickup is offline
Old 01-18-2007, 04:31 AM   #12 (permalink)
TYP-4 I'm in yakima WA. I see your in Oregon maybe we could arange something
The bale wagon with the current 460 can do about 55 at about 3000 rpm. it has a 2 speed rear end using low range for loading and high for transport. it currently has a new prosess 4 speed manual which requires a lot of inconvient shifting, all of the new bale wagons have diesel and auto but cost about 120,000 so i want to convert mine.
a bale wagon is a machine that picks up hay bales out of the field and stacks them in a block on the bed of the machine, It holds about 90 bales and then dumps then in a stack.
I think that a c-6 would be alot easier to retrofit, are they a very durable trans? the machine loaded weighs about 25K but has a very low rear end.
I have found a wrecked 1992 donor but not bought it yet, it sounds like I need to find one older or a good 7.3 engine.
4.30 gears auto
Old 01-19-2007, 02:55 AM   #13 (permalink)
anybody have a good used 7.3 in the northwest?
4.30 gears auto
