Old 04-01-2006, 11:58 AM   #1 (permalink)
Diffrence between F and K diesel?
What is diffrence between F and K turbo diesels? By the way my rig is a 94 turbo IDI....
I got the bolt out from tensoener pulley but cant get it out because of another pulley below it, cant even get the nut to come lose on that pulley without having to ruin it so I am in a bind, so can I just cut out the housing on the tenoner pulley? What about the spring will it spring on me?
Not sure I am having any luck finding the part/ the part for the K diesel is not avail but it is avail for the F diesel..... [img]/ubbthreads/images/graemlins/smokin.gif[/img]
David and his Ford truck with a little motor and a big idea......
Ford F-350 Dually Crew Cab 5-Sp 7.3 IDI Centurion Conversion. No mods, rebilt IP and replaced injectors. Used as personal driver and pulling my RV camper.
Planned upgrades are a new and better turbo and larger exhaust pipes than the 21/2s that are already under the rig/ would like a 6 spd tranny but dont know if that is a feasable or smart investment yet.
1993 Dodge 3/4 ton Van Conversion 318CI
1978 Dodge Magnum XE T-top Classic 4BBl 400CI (Honeymoon Car)
1965 Dodge Polara 4 DR 383CI
AmaMoparmanbutlikeForrrrrdtrucks
truckdrivindave is offline
Old 04-01-2006, 12:15 PM   #2 (permalink)
Re: Diffrence between F and K diesel?
Most likely IDI turbo and PowerStroke. They were both available in the 1994 model year.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 04-01-2006, 08:23 PM   #3 (permalink)
F is the Powerstroke and K is factory turbo IDI. Internal parts are very different. Are the tensioner bolts any different?
J.D.'s Fords: 1986 F-250 6.9 diesel Solid State Glow Plug System 3.55 gears C-6 2WD 178,960 miles.... it still runs pretty good!
Wishlist H-max turbo, T19 tranny,
1989 Ford Ranger ga$$er, non runner, soon to be donated or scrapped!
jdkline is offline
Old 04-01-2006, 08:35 PM   #4 (permalink)
Yes, they are different. You need a torx bit to get that one out.
You can grind the head off then try to extract it. You'll need it off to get that tensioner off.
2006 GMC K3500 CC DRW 4x4
1994 F-350 DRW PS w/ zf5
1996 Town Car
mgraveman is offline
Old 04-02-2006, 01:52 AM   #5 (permalink)
My Photos: (17)
And the answer is...(drum roll, please)....<font color="red">UC</font> [img]/ubbthreads/images/graemlins/biggrin.gif[/img]. sorry, I just couldn't resist. [img]/ubbthreads/images/graemlins/shrug.gif[/img]RichardCranium
<font color="red">1987 F350, 4X4, Crew Cab, DRW, w/'91 7.3 TURBO-CHARGED BY ATS, no-Wastegate(Turbo rebuilt by me 7/2005)</font>, <font color="blue">E4OD Auto, Aux Trans Cooler w/12" fan, w/Baumann Programable Trans Computer-12/05</font>, Rebuilt Injection Pump-2/03, Electric Fuel Pump, Coolant Filter, "BajaGringo Block Drains, 5-Row Radiator Core-9/04, 2 New Plastic Fuel Tanks w/new Sending Units/Pickups, Fuel Filler Neck Mods, Air Ram Intake, Air-Lift SuperDuty AirBags with Smart Lift Auto Leveling-7/2005 <font color="blue">Link to Photo of "OkieGringo Idler Pulley"</font>
<font color="red">Link to GP Controller Diagram</font> <font color="blue">Link to "Electric Fuel Pump Wiring Diagram"</font>
OkieGringo is offline
Old 04-02-2006, 10:18 AM   #6 (permalink)
Yeah I figured all that out looking for the parts yesterday. Today I am going to NAPA to see if they have it...If not then on to Ford tomorrow......I can find part for the 93 model and the F engine 94 model but not for the K engine....It was not available or they did not carry it. Imagine that?
Well I got the parts off finaly yesterday evening just before my grand daughter was born/I am a poppy again hee hee, so I had to suspend any more work on my rig till today/ well got a new idler pulley but no luck on finding the tensioner pulley/ Hopefully NAPA will have it so I can drive it to work tomorrow.....
Is this a common problem? because the tensioner pulley was new about 2 1/2 yrs..... [img]/ubbthreads/images/graemlins/smokin.gif[/img]
Old 04-02-2006, 11:10 AM   #7 (permalink)
Mine is the K - all the auto part stores tell me on the phone - it should be an F or an M - and I say it's the K - I tell them it's the last of the IDIs, turbo etc, and they go Hummmmm... I guess the inexperienced ones answer the phones.
Silver Liner
1994 F-250 XLT Supercab 4x4, 7.3 IDI Turbo; E4OD sometimes getting the blinking O/D. Loaded options. 4 prior owners.
Reinstalling '93 OEM 31" radiator.
Regularly tow 6x12 trailer @ 2500 lbs, loaded.
2050 rpm @ 65 mph.
18 mpg hwy. (Up from 14 when bought)
Currently use Power Service.
bcreighton7 is offline
Old 04-02-2006, 12:23 PM   #8 (permalink)
Assuming there's no difference in the parts between a 93 and 94 turbo IDI, you could just ask for parts for a '93. That would limit the engine choices to IDI turbo and non.
Old 04-02-2006, 02:10 PM   #9 (permalink)
Hey Dave, Congratulations on your new granddaughter. Tim
'94 F250, 4X4, 7.3, E40D, 4.10, 126K
tim94f250 is offline
Old 04-02-2006, 11:03 PM   #10 (permalink)
So what is the difference between my truck engine and the K engine? Besides having a turbo.
1990 F250 4x4 7.3l IDI 3.55 E4OD 250?k
1997 2500 Ram 2wd Cummins 5spd 3.54 286k
RunRed is offline
Old 04-03-2006, 04:38 AM   #11 (permalink)
As I understand it is that the K engine is the IDI
the F engine is the Powerstroke that came out later that year
the M engine I dont have a clue, Ive run across it a few times but dont have a clue. I can only access that that it might be the engine used on vans, I dont know.
BTW NAPA did nto have the tensioner pulley in stock and it will take 7 to 10 days to get it here unless I fed ex it or something.
Today I am going to see if Ford would have it or get it to me sooner.
Old 04-03-2006, 08:40 AM   #12 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: Difference between F and K diesel?
Position 1,2, and 3- Manufacturer, Make and Type
Position 4 - Brakes/GVWR Class
Position 5,6, and 7- Model or Series f25 = F 250
Position 8 - Engine Type
C or K - IDI
F - DI
I or M - DSL
Position 9 - Check digit
Position 10- Model Year 1994 - R
Position 11- Assembly Plant
Position 12- Constant "A" until 99,999 is reached when "B"
Position 13 through 17 Sequence number beginning at 0001
IDI - Indirect injection (turbo diesel)
DI - Direct injection (turbo diesel)
DSL - Diesel
If needed, give us the position you want to know about.
See my gallery for the serpentine pic and bolt sizes, rotation etc.
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 04-03-2006, 10:23 PM   #13 (permalink)
So when comparing a 1994 IDI TD to a 1994 DI TD (powerstroke) which is it that people prefer and why? From the specs I have seen the IDI has the max torque at 1400 and the DI has it's max at 2000 but I do not know the real world feeling or maintenence differences or anything between the 2.
RunRed is offline
