Re: Dip Sticks
You'd have to be careful with that method...it is ONLY accurate if the trans fluid is warm and has been shifted through all gears, sitting on level ground, etc.
About your engine oil dipstick- there should be a small mounting bracket tack-welded onto the tube that holds it fast against the engine block. The tube simply presses into the oil pan, and is sealed with an o-ring. It's a pain, but I'd wiggle the whole thing out of there and check for the bracket and for the o-ring.
--motor/trans sold--
2000 VW Jetta TDI = 48+mpg
1997 Dodge 3500: 2WD Cab & Chassis, 12V Cummins, 47RE Automatic, Dana 80, 194,000mi. Parting out.
1989 12V VE Cummins out of Chevy C60? at the machine shop...going into the Ford.
Member of Indiana Air National Guard 122FW MXS
