does zf5/1356 have pto - Diesel Forum - TheDieselStop.com
Old 03-04-2005, 11:54 AM   #1 (permalink)
[img]/ubbthreads/images/graemlins/shrug.gif[/img]does 94 f250 in sig have pto on trans /transfer ??
94 f250 7.3 turbo diesel 5spd 4x4 (only mod luk s
mf)
1976 f 250 s/c 2wd (project truck)
commonsthor is offline
Old 03-04-2005, 01:29 PM   #2 (permalink)
cdnsarguy's Avatar
My Photos: (109)
Re: does zf5/1356 have pto
PTO I believe was only on F350 with 1356......
Proud Canadian BOOB man too!!
cdnsarguy is offline
Old 03-04-2005, 08:36 PM   #3 (permalink)
Dave Haven's Avatar
My Photos: (16)
My ZF on my '89 F-250 has 2 PTO "ports".
"Big Red"-'89 F-250 4X4 reg cab; 7.3; Cat ELC (no problems, ain't skeered ; 4.10 axles; 5-speed ZF "Bolt-Action"; ATS turbo installed @ 158K; Holley "Red" pump; new injectors and 2nd Reman IP@ 234.5K; "Coffee Can" (4") downpipe-back exhaust....
6220#
"Trick Truck"- 1970 F-350 w/custom utility bed and cabover camper; Cadillac leather seat; CAT 3208 w/turbo from CAT 613 scraper; 5" straight pipe; 6-speed Allison "slush box"; 3-speed "Brownie"; 2-speed Eaton rear axle from F-600; Custom rear deck w/ air compressor, Lincoln arc welder, Oxy-Acetylene rig, and boom crane....
17,940# 26' Class C motorhome
"White Pony"- 2007 Mustang; 4 liter V6; "5-shot bolt action" (an automatic in a Mustang is just WRONG!)
Dave Haven is offline
Old 03-04-2005, 09:26 PM   #4 (permalink)
Supporting Member
brett_kartracer's Avatar
Mine has two ports too. To find out if yours can take a PTO, look on the sides of your tranny (not transfer case) and see if there is one (or two) 4 in. by 6 in. (approx.) plates bolted to it with about 8 bolts. These plates are in the place that the PTO/s would connect to. You'll probably have to order a PTO for it if it doesn't have one yet.
-Brett
2001 F-250 Powerstroke, Automatic. Zoodad mod, Airaid filter, muffler delete, Boost fooler, Edge Evolution, Turbonetics 0.84 turbo. Best 14.88@88MPH, 314hp@617trq.
1989 F-250 7.3 IDI N/A, 5 speed, no muffler. Injector Pump turned up 145*.
brett_kartracer is offline
Old 03-05-2005, 01:14 AM   #5 (permalink)
What could you attach to the PTO ports? compressor? Generator?
Or am I way off?
hydraulics?
92.5' F-350 XLT RegCab 7.3l IDI N/A
2" Lift 35"x12.50x16.5 Continental M/T's
Manual 5 speed
3.5" downpipes to the Y 4" Straight Piped exhaust
<font color="blue">Beautiful British Columbia,</font> <font color="red">Canada </font>
2001 Ford Explorer Sport Trac
4x4, 3.73 Gears, HID Lights,Black
1986 Toyota Pickup 4x4, Reg cab longbox
33 x 12.50 M/T's, Smittybuilt Bumpers, Offroad Lights, 3' Body lift, Autometer Sport Comp Tach, 86 Supra Buckets, Also Black.
Bigsturg is offline
Old 03-05-2005, 06:39 AM   #6 (permalink)
Well,in my experience, you can hook about anything you want up to it. I know a few places that use this chassis for a fire truck have connected a small fire pump to these ports. What you need to look into is how much force can be run through these ports versus how much force is needed to run the accessory. PTO's typically won't take the full the force that is produced by the motor. Also, you need to make sure the PTO that bolts on is the right gear ratio to run whatever accessory you are looking at. The name I typically see on fire apparatus is Chelsea. They've been around a long time, and could help you get your hands on a PTO as well as make sure the application is correct.
Proud Dad (0wner) of 2 IDI's and a Cocker Spaniel Mix. A the IDI's are both F250, 4x4, 5spd manual, standard cab, long box. The 89 is maroon and out of service and the 90 is Blue. The cocker spaniel is about 7-8 years old, he was a stray.
twin_diesels is offline
Old 03-05-2005, 08:12 AM   #7 (permalink)
[img]/ubbthreads/images/graemlins/smokin.gif[/img]i will check at lunch today for the ports ,iwant to try and run air compreessor off of pto,is that possible?
mf)
Old 03-05-2005, 09:57 PM   #8 (permalink)
What is involved in adding a PTO on a truck without one? (in terms of time and money)
Thanks.
1997 F350 Powerstroke Crew-Cab XLT 4X4 5spd 145,000 miles. Tymar Intake, ceramic coated Hypermax downpipe, full 4"exhaust with 36" muffler, Calf. fuel Reg kit, HPX crossover kit. Bushwacker extend-a-fender flares, grill and bezels painted to match truck, 305-70-16 Goodyear Wranger MTR's. For Now!
GO BUCKEYES!!!!!!!!!
Rex_Reimer is offline
Old 03-06-2005, 11:55 AM   #9 (permalink)
Well, a few comments here. A used PTO must be matched to that particular transmission...the PTO housings and bolt pattern are usually standard, but it's the gear pitch/tooth count that matters. New PTO's are not cheap...about $800.00 CDN for a basic model. The PTO is simply a means of using engine rotation (through the tranny) to power an accessory. Most common accessory is a hydraulic or water pump. Keep in mind that the PTO is only one component...if you are trying to set up a dump box for example, you'll also need a pump, hydraulic hoses, a tank, a valve controller (for up/down), cylinder(s), controls for the PTO engagement itself and for the valves, and maybe even a scissor lift [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
It can be intimidating at first, but the systems are in fact pretty simple...you just need to do your homework, determine what your real NEEDS are, and price stuff out FIRST. Gallons per minute capacity (GPM), flow pressures, reserve tank size etc are important.
Guess what I'm saying is that you can certainly make something up. New is going to cost $$$, used not so much, but harder to find right components. It's too bad you don't have Princess Auto close by. They are outstanding for hydraulic components at great prices.
Some alternatives: underhood pump or compressor. I have seen several trucks that utilize an underhood compressor (or hydraulic pump). Typically it is mounted where the AC compressor would be, and are electrically controlled centrifical clutch units driven off of an accessory belt.
Electric powered pumps can work for occassional use application, but they aren't much good for anything other than running a snow plow or dump lift cylinder. Very low GPM rating typically.
And a few trucks I've seen mounted a small lawnmower engine underneath the truck powering a compressor. And some people just use gas station compressors [img]/ubbthreads/images/graemlins/biggrin.gif[/img].
Anyhoo...hope I have shed some light. Anything is doable...just wanted to make sure you do your homework before jumping into this.
91 F350 7.3L ZF-5 Speed 4.10 New Project Truck and lots to learn!
Also Own:
95 Freightliner FL70 5.9L Cummins (inframed at home) 6 speed Fuller, 11R22.5, 4:10, 4" exhaust and stack with a teeny weeny muffler [img]/ubbthreads/images/graemlins/smile.gif[/img], 14,000lb Stellar Hooklift for lifting waste containers
81 F350 351M C6 4.10 14 Yard Dump Body and 6mpg!
98 Dodge Cummins 5.9L-12V 5 Speed 4.10 LS 3500 Dually 4x4, 420,000 on odo, Chelsea PTO pump, 12K winch, 14 yard Dump Body, worn out shift knob and driver seat, no silencer, Boost, Pyro, no muffler, gutted kitty, lots of mud.
vonTrapp is offline
Old 03-08-2005, 03:01 PM   #10 (permalink)
ColLonewolf's Avatar
Do not forget that a lot of really heavy duty winches are run off the PTO.
1989 Centurion Classic 350 4X4 (F-350 4door Bronco), W/93 7.3L IDI non-turbo, ZF 5-Speed(LUK)/BW 1356/Dana 60/Sterling 10.25, 3.55, Hypermax Turbo/Intercooler, 3 1/2&quot; Exhaust/Pyro(inop), RDT, 265/75R16 BFG/AT on 16X8 American Racing Wheels 138K and still going strong
1983 300SD Turbo Diesel, 3.0L Inline 5, 4 Speed Auto, White/Parchment, VDO Boost Gauge, 215/60R15 Bridgestone Potenza RE960AS Pole Positions on 15X7 15 Hole Wheels, Straight Piped, 298K?
ColLonewolf is offline
