Old 08-29-2007, 09:42 PM   #1 (permalink)
Drum brakes....from napa
Ok, I bought shoes from napa. the two shoes that were marked secondary left/right were short and a long pad. My understanding was that both secondaries should be the longer pad and the primary(front) pad should be shorter. If i follow the markings they gave me, then the driver side would have two shoes with long pads, and the passenger side would have both shoes with short pads. Am I wrong or did the napa reman screw up??
7.3 IDI F-350 4x4 1990
-Custom: '92 interior; Banks Y Pipe, Flowmaster muffler and Dual 4.25" Stacks
-Reman'd: Heavy Duty E4OD and Billet Converter; Transfer Case; Water pump; Power Steering pump
-New: Brakes; Engine seals and oil pan; Oil pump; RUST-FREE Cab and Bed
-Pro Comp "Holley Red style" electric fuel pump
-3" Body Lift
-Fresh under coating on frame No more face full of rust under the truck!!
-16x10 Eagle Alloy 186 with 33's
-8ft snow plow
-Soon to come-
Mid 80's front clip
Matching fender flares
Black paint job with chrome trim (fender flares, grill, bed runners, wheels, exhaust stacks, windshield trim, bumper)
2.5" leveling kit
4.6l Mustang GT 1997
-Custom side exhaust (no mufflers, Ford Racing Exhaust tips
-Aftermarket stereo (Alpine headunit; JL Component Speakers; JL 300x2 Amp; JL 10" W7 Sub; JL 500x1 Amp)
GOTTA LOVE FORD MUSCLE
Cjhstang is offline
Old 08-29-2007, 09:56 PM   #2 (permalink)
88beast's Avatar
Re: Drum brakes....from napa
well the primary is larger and secondary is smaller they are messed up for what you see it is one big one small per wheel if not the right will brake better than left
88 F-250 body,550 rear frame setup, 7.3 idi, 3:73 dana 80 rear, srw, dana 50 front, heavy duty leaf springs, back up camera, 20$ wallyworld fog lamps, class 5 bumper hitch welded to frame and gusseted, 32" steering tires all around, ac power converter,jeep bucket seats, deezee runningboards (cab only),cobra 29 cb w/ 102" whip, 2 trucklight worklights on front stake pocket each side,high lift jack behind seat, toolbox for the junk, visor, running lights, 6600 lbs with all my junk
http://youtube.com/watch?v=ILAQuHNAGE0
i plan to add propane kit, stake body bed, gn hitch,western style mirrors, and a lot more
88beast is offline
Old 08-29-2007, 09:58 PM   #3 (permalink)
Is the larger one supposed to be on the back side or the front side of the hub?
-3" Body Lift
-8ft snow plow
-Soon to come-
Mid 80's front clip
2.5" leveling kit
Cjhstang is offline
Old 08-29-2007, 10:14 PM   #4 (permalink)
88beast's Avatar
i think front not sure usualy the front does more braking so id think front ill look at my truck if i can tomorrow for you
88beast is offline
Old 08-29-2007, 10:26 PM   #5 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Stang..... I emailed you the picture. The small shoe goes to the front and large to the rear......
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 08-30-2007, 02:40 AM   #6 (permalink)
Thanks for the pic! I installed them just as it shows in that pic. Thanks for the reassurance. I never really expected remans to have incorrect labels on them.
Thanks all
-3" Body Lift
-8ft snow plow
-Soon to come-
Mid 80's front clip
2.5" leveling kit
Cjhstang is offline
Old 08-30-2007, 12:00 PM   #7 (permalink)
My Photos: (27)
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body"> well the primary is larger and secondary is smaller they are messed up....
</div></div>
Absolutely wrong, the primary shoe is smaller and the secondary is the larger shoe. The primary shoe always goes on the front of the backing plate, the secondary to the rear.
<div class="ubbcode-block"><div class="ubbcode-header">Quote:</div><div class="ubbcode-body"> usualy the front does more braking </div></div>
Wrong again, the rear shoe always does more braking on any brake system.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 08-30-2007, 12:04 PM   #8 (permalink)
88beast's Avatar
ok i mentioned before that i was not sure but i do rember that each wheel had a large and small shoe
88beast is offline
Old 08-30-2007, 07:03 PM   #9 (permalink)
Short brake shoe is mounted toward the front of the vehicle.. longer shoe is on the back...both sides..
ASE Certified Master Mechanic
1994 F250 ZF5 turbo(factory) a work in progress 208000 miles and counting..
Retired in 2005 more time to work on the truck!
34 years as a ford prototype mechanic.. Now running a big truck shop... series 60 detroits mostly...
roamer37 is offline
Old 08-30-2007, 07:23 PM   #10 (permalink)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: 88beast</div><div class="ubbcode-body">ok i mentioned before that i was not sure but i do rember that each wheel had a large and small shoe </div></div>
Just remember it's a forward energizing brake system. The tops of the pads get pushed toward the drum by the wheel cylinder. This causes the front smaller pad to get pushed around by the drum to then engage the bottom of the rear pad. So the front pad is shorter because the bottom of it would never even really wear if it were there. When the vehicle is driven in reverse the opposite happens and that's how the the self adjuster thing is adjusted.
Eric
Ford 1992 E-350, 6,900 lbs.
Dodge 1997 Ram 3500
Ford 2005 F-350
yaric008 is offline
Old 08-30-2007, 07:31 PM   #11 (permalink)
88beast's Avatar
oh ok that helps explain it lol
88beast is offline
