Old 10-11-2005, 11:41 AM   #1 (permalink)
DT466 swap
I've been contemplating a DT466 and tranny swap what are your thoughts. Forget powerjoke swaps this is the real heavy duty
1989 F250 7.3 N/A 2wd bone stock finally fires in the cold!!!!!!!!!!!!!!!!!!!!
dont miss out ***************
Proud BOOB man http://p087.ezboard.com/bmidatlanticforddieselclub
dbarilow is offline
Old 10-11-2005, 04:20 PM   #2 (permalink)
Re: DT466 swap
I actually had been wondering about the same swap, but havn't seen or heard anything about one being done.
1993 F250 4x4 supercab, 7.3 NA, E40D, 3.55s---now deceased, mashed and totalled by a drunk driver---much cheaper to just "run what ya brung" than to buy new.
k2bronco is offline
Old 10-11-2005, 11:35 PM   #3 (permalink)
Re: DT466 swap
I know of one truck with a 466 in it and I think it was a pretty tight fit.
Allen
93 F250, regular cab, 4x4, 7.3 NA, ZF5, 3.55, 209k miles, came home 2/28/06, soon to be turbo.
92 250, regular cab, 4x4, 7.3 NA, E4OD, 3.55, 316k miles, came home 8/28/04, aluminium 16x7 wheels, 285/75/16 Sport King AT.
89 250, extended cab, 4x4, 7.3, ATS wastegated, 5" straight pipe, hand shaker, 4.10, slightly toasted, waiting for a new cab and front end, came home 12/24/04
aaklingler is offline
Old 10-12-2005, 02:10 PM   #4 (permalink)
My Photos: (23)
Re: DT466 swap
Finally! Somebody with vision. [img]/ubbthreads/images/graemlins/grin.gif[/img] I wish I had one laying around. I'd try it. Figure on a body lift as a pre-requisite, and go from there.
- Mel
1983 F-250HD 4X4 The Moose Truck - Moose Pump, DPS Injectors, Hypermax Turbo, GV 7spd., 3.54 Gears, Moose Air, RDT, Dual Stacks, 35"tires. My Album 55MPH at 1400 RPM. 19MPG Avg.
1993 F-350 CC DRW The Lady Moose - Hypermax Turbo, GV 9spd w/Double OD. 4.10's. Dual Exhaust, custom trim, turned up 6.9 fuel system, Lucky Flywheel.
1987 Bronco The Moosestang 1987 Bronco Diesel 6.9L C6 4X4 with 3.54 gears, 2" body lift.
HeadGasket/Turbo Article
A BOOB man! Visit EZBoard.com and search for IDI.
agnem is offline
Old 10-13-2005, 04:20 AM   #5 (permalink)
Re: DT466 swap
Do you mean a 466 will fit without major modifications to the truck?Hmmmmm,maybe I will only build one 7.3L engine.......
IDI Till I Die!!!
NCC-1701UAV U.S.S. Enterprise -1991 F350 CC dually.Lighted heated west coast mirrors,Nathan Airchime K3HA air horns,attitude from hell itself!
1994 F350 Crew Cab Dually,7.3 IDI turbo-Currently in the Roundhouse awaiting 10 year overhaul. White Lightning
1971 M35A2 deuce and a half.6wheel drive,Power Nothing!125 Horses in a 13,000lb truck.Real get up and go power! Martyr Machine
Cousteau 2006 Ranger STX-3.0 V6,5spd handshaker,standard cab
m35a2 is offline
Old 10-13-2005, 05:16 AM   #6 (permalink)
My Photos: (33)
Re: DT466 swap
I would like to put one of those in my IH S series.
95" Extd Cab F250HD 4x4 DRW, /86"6.9 T19 GV o/d 3.73 axles, Hypermax Pulse turbo, intercooled / Modified Hypermax ram air induction, PowerShot 2000 LPG system "first design". Ride rites @ all 4 corners, Dana 50 mono Beam up front, Ford 10.5" in rear with 4 wheel disk brakes. Other Truck, 1983 IHC "S" with 14ton NoMar wrecker body, 30,000 GVW, 229"wb with a 6.9L IDI, Clark 5sp, 5.57 rinp&pinion, turbo charged and intercooled (with LPG soon).
Huff is offline
Old 10-13-2005, 12:23 PM   #7 (permalink)
Re: DT466 swap
What do you consider major modifications?
Allen
Old 10-13-2005, 01:32 PM   #8 (permalink)
Re: DT466 swap
I have a couple of those engines around here, and have considered it myself. I reconsidered when I done some measuring though and found it would take quite a bit of work. It can be done, because I have saw a mid ninties ford with one in it, but like I said it will take quite a bit of work. If you do the swap you will have alot of power potential though!
2006 F-350 XLT,FX4 4X4,CC,SRW,LWB,6.0, auto
IHpower is offline
Old 10-13-2005, 01:42 PM   #9 (permalink)
Re: DT466 swap
BOY!! talk about 10 pounds of rump roast in 5 pounds of jeans!! i think the biggest issue would be with the pan. you would need to rotate the sump, as all HD Truck engines use a front sump (clear the solid axle). guess slice it carefully around the pan rail. rotate it 180', reweld it up, and make a cutom pick up tube. the next issue, you will need like a 3-4" body lift, as the 466 is 8-9" taller than the 7.3l. now, on to length, likely you will not have A/C, as the radiator will need to be infront of the support rather than behind the support as it is now. if i were to do it, i would rather do a DT360 as it is shorter and not quite as tall. seems to be a better fit. the 360 will be easier to cool, as well as easy to fit. for trannies, i would likely use a spicer 5 speed out of a f series HD truck (l,ln,f600 and up), they have the SAE bell housing and will hold up to the power and weight. plus you could have a cool PTO to run hydraulics like a winch.. i believe the final ratio on most Gas trannies are 1.17-1 meaning you will need 3.08-3.54 gears to do any real highway driving with tires under 33" tall. diesel were in the range of 1.04-1.09, and will do better, but the cost will likely kill you. gas ones are a dime a dozen, and most yards will give the things to you. the diesels are a bit rarer, and are worth there weight in.. well.. aluminum, maybe silver. last gasser i bought was for a ln800 with a 429 Lima Industrial. think the yard got me in the range of 175 with no core charge. it even came with a Dana rear facing PTO with a 1" shaft on it..
HMMMM saw a 84 350 CC DRW with a bad 6.9l in the paper for 750.. maybe its time for a winter project... oh man, my wife would kill me. 4 diesel trucks, and only 2 drivers...
huskyhauler is offline
Old 10-13-2005, 01:43 PM   #10 (permalink)
Re: DT466 swap
Major mods include Moving firewall back so far the dash has to be relocated.Body lifts,Cowl hoods,etc I don't mind......Hmmmm,White Lightning might get a DT466 if it can be done relatively easy.
IDI Till I Die!!!
m35a2 is offline
Old 10-13-2005, 02:50 PM   #11 (permalink)
Re: DT466 swap
I don't believe the fire wall was moved, and I'm pretty sure the dash wasn't, not sure what he did with the oil pan and radiator.
Allen
Old 10-15-2005, 12:54 AM   #12 (permalink)
Re: DT466 swap
hmmmm,looks very possible.The engines are nearly the same size other than length(Using the 444E measurements,Ok,its a PSD but international doesn't list the IDI).
T444E
35.7" long
29.4" wide
36.6" tall
930Lbs Dry
DT466
45.1" Long
29.3" wide
40.8" tall
1425Lbs Dry
Hmmm,only 9.5" longer.A cowl induction hood can fix the extra 4.2" in the up department.....I wonder if our front end can handle that much weight....
IDI Till I Die!!!
m35a2 is offline
