dual fuel tank capacity - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 05-24-2011, 03:37 PM Thread Starter
what is the capacity of each of the tanks in a 88 f350 crewcab dually? does the capacity vary through the years or are all dual tanks same capacity? also does anyone have a link on a guide to dropping the tanks? dont need it but would like a reference.
'88 F350 Crewcab Dually 2WD 6.9L ATS Turbo 4.11
vp119 is offline
post #2 of 7 (permalink) Old 05-24-2011, 04:33 PM
NH2112's Avatar
Send a message via MSN to NH2112 Send a message via Yahoo to NH2112
They should be 19 gallons apiece.
Phil
Check my lists of common part numbers in my photos! Updated often!
1991 F350 Lariat XLT, 7.3l, 5-speed, crew cab, SRW, 3.55, 2WD.
1990 Jeep Wrangler Sahara, in the process of a major overhaul/upgrade. OM617 on the horizon! Front & rear Dana 44s from a Wagoneer till I get some 1-ton axles built & narrowed, and eventually a front shackle reversal. Diesel YJ, bay-BEE, and not a cookie-cutter 4BT conversion!
NH2112 is offline
post #3 of 7 (permalink) Old 05-24-2011, 05:24 PM Thread Starter
thanks NH2112, just got it running again, looks like im going to do the hutch conversion because it wont run on 1/4 tank :/ but fresh filters all around and it runs smooth.
vp119 is offline
post #4 of 7 (permalink) Old 05-24-2011, 05:24 PM Thread Starter
NH2112 do you know where the water seperator is on this thing?
vp119 is offline
post #5 of 7 (permalink) Old 05-24-2011, 05:40 PM
chuckster57's Avatar
The Factory water seperator on the 6.9's should be on the firewall. D/S IIRC.
Train Horns:
PM please not visitor message
chuckster57 is offline
post #6 of 7 (permalink) Old 05-24-2011, 08:58 PM
NH2112's Avatar
7.3ls have a single filter that functioned as a filter and water separator, so the PO might have just bolted all the 7.3l accessories onto the 6.9l and not installed the separator.
Phil
NH2112 is offline
post #7 of 7 (permalink) Old 05-24-2011, 09:07 PM Thread Starter
ok thanks, i didnt find it anywhere so i think that is exactly that was done. thanks again.
vp119 is offline
