Okay I titled this just like the old post (3/2/06). I have the same symptoms. I've checked all connections. Checked the TPS and got a low reading of 1.22v and high of 3.85v. After reading the old post I'm still not sure just which way to go. Should the TPS be exactly 1.00v and 4.3v on the high side? Didn't see any bent pins, broken wires, water or anything.
'94 F350 XLT Dually
7.3 TIDI/E4OD w/ 206K
stock but not 4 long [img]/ubbthreads/images/graemlins/wink.gif[/img]
3/31/07 re-done GP system
4/15/07 New Brake System!
8/17/07 ATS Exhaust System (cheap)
Shift linkage.. internal external or cable.. damaged misadjusted or disconnected
Improper pressures.. low line pressure
Pump inlet filter and seal assy.. plugged/damaged..filter seal gamaged/cut
There are six other areas of concern......all going deeper into the trans than the Harveyhandyman should/could go...
Ok. I finally got around to replacing the TPS. No change in the way trans works. Question is what exactly should the reading on the voltmeter be? In an old post I saw less than 1V at idle and no more than 4V at WOT. Right now I have .70 at idle and roughly 3.4 at WOT. What should I be looking for?
'94 F350 XLT Dually
'94 F350 XLT Dually
The engine RPM required: is curb idle which is 650 rpm, warm engine in gear....... so set the warm engine rpm, then shut it off and do the FIPL setting while warm.
