E40D custom application.. need shorter dipstick..?? - Diesel Forum - TheDieselStop.com
Old 07-10-2009, 04:03 PM   #1 (permalink)
Hello,
Im using an older E40D tranmission to drive a gearbox on a log/wood saw mill.. I'm looking for a dipstick that will fit in the SHORT dipstick tube coming out of the transmission... The original dipstick tube "extension?" is pulled out and now its just the 8 or 10" or so tube coming out of the transmission that I'm looking for a dipstick to fit... The factory dipstick fits good enough but obviously its like 3 feet too long..
1. should I use the original dipstick and cut it to length... but I dont know what the correct fluid level is supposed to be at, as i dont have the original dipstick tube to use to get the correct level...
2. is there a dipstick that is already made to fit this application?
Your thoughts?
boomvan is offline
Old 07-10-2009, 07:41 PM   #2 (permalink)
If you give me a week I can probably give you an answer on length from the top of the lower tube. I have had an e40d in and out 3-4 times trying to figure out why it won't go. I had the oil level perfect when I took it out last weekend, but now the rebuilders have it back trying to figure out why it won't function. I think the level needs to be higher than the intake to the filter. Thats what it looks like anyway. There's plenty of guys on here that can probably give you an answer.
I have a question though: Are you running the electronic controls on the E40D? or it just stand alone without controls? How does it shift etc? I can't get a straight answer from everyone whether the E40D will operate without the PCM.
mutantvan is offline
Old 07-10-2009, 10:08 PM   #3 (permalink)
Mark Kovalsky's Avatar
The straight answer is that with no electronics the E4OD will operate in 4th gear with an unlocked torque converter if there is no PCM. If you move the shifter to 2 you'll get 2nd gear, in 1 you will get either first or second, I can't remember. Reverse will work.
Mark
Mark Kovalsky is offline
Old 07-10-2009, 11:31 PM   #4 (permalink)
Like Mark said - the E4OD will operate without a PCM, but it will enter FMEM state, aka limp-home mode - if trans was still in the truck putting the shifter manually in 1st or 2nd position will give you 2nd gear, and putting the shifter in D will give you 4th with an unlocked converter.
M.L.S.C. is offline
Old 07-11-2009, 12:19 AM   #5 (permalink)
Bill1013's Avatar
I'll let you know sometime this evening, since you are in Fairbanks, you are 4 Hrs. behind me "EST". I have the short S shaped tube and dipstick, I'll measure it. Time now is 12:15 AM, your time is 8:15 PM . Was in Soldotna Alaska last summer at this time, damn daylite until 2:00AM
99.5 F350 XLT Lariat 4X4 AT 4.10 DW CC LB Centurion conversion Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U
1990 F350 XLT Lariat 7.3L IDI E4OD Dually 280K+ 2WD
Reman Promar Long Block 11/07
http://community.webshots.com/user/oldbull8?
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast.
One Flash and it's gone forever.
Bill1013 is offline
Old 07-11-2009, 01:34 PM   #6 (permalink)
Thanks Mark! That helps me out a bunch.
Old 07-11-2009, 01:35 PM   #7 (permalink)
Thanks that really helps me sort some gobblygook out that I have been getting from the parts store.
Old 07-30-2010, 05:13 PM   #8 (permalink)
6.9Guy's Avatar
did anyone ever figure out how far down the dipstick should be in a custom application like that? if so it'd really help me out too
84 F250 4x4 6.9, Reg Cab, T19, 160k miles, Straight Piped, 2.5'' lift on 33s, 3.54s - FOR SALE, PM me if interested
94 F250 4x4 7.3 IDI, ATS Turbo, 3 inch DP to 5 inch straight pipe, E4OD, King Pinned Dana 60 straight axle sawp, 7" front 4" rear lift - "cali leanin" 35s on 20s, 4.10s
95 F250 4x4 460 Gasser, Banks Stage 3 Power Pack, Headers, Straight Piped, Intake and Injectors, E40D w/ banks trans command, 4.10s Aka the Tow Master
6.9Guy is offline
