I have a couple of the Banks Transcommander that Banks supplies with their Sidewinder Turbo upgrade for the E40D. One is specifically for the pre 95 E40d (unused), other is for the later model after 95,(used 3 months on my E40d), it will work on pre 95's as well. I installed it and found out later it was specifically for the later models. Called banks on the issue and was told, no problem just a slight difference in resistance in the unit. I removed it when I upgraded to an ATS HD Built E40D and Billet triple disk torque converter (converter is now controlled by its own controller by ATS)14 months ago.
However I wish I had known about the Banks Transcommander 5yrs prior to upgrading the tranny. I believe it would have saved me the ungrade.
I had the truck in for a tranny oil change, and the tech showed me the material and fillings in the pan and said I was headed for a rebuild. I had replaced this tranny and stock converter 6 yrs prior with a Ford rebuild, shortly after I purchased the truck in 98.
Everything was working Ok, but fiqured I needed a more bullet proof tranny & torque converter, to start pulling a 10,000 lb 5th'r.
The stock converter is your biggest problem area, the Banks Commander will change the performance of the tranny considerably. Higher line pressures and firmer shifts. I was very satisfied with it, but installed it to late on my tranny at the time. ATS would not warranty their tranny with it installed, wanted theirs instead, besides now I can dial in the speed that I want the converter to engage(dash mounted unit, cool).
Give me an email if your interested in purchase around $180 for used one, or $200 for unused one. Will be going on Ebay in a couple weeks.
RGDani4042@aol.com
1990 F250 Ext Cab, 4x4, Banks Sidwinder Turbo with Monster Exhaste, ATS HD E40D Transmission with ATS triple disk Torque Converter with commander. Gear Exhaust mounted brake. Rebuilt IP and Turbo type injectors, Inbox 50 gallon axillary tank, HD frame mounted Goosenick ball in bed, pulling a Carriage Royals International loaded to around 10,000 lbs with no problem.
