Old 10-10-2006, 03:58 PM   #1 (permalink)
E4OD Diagnosis
Within the last 2 months I have replaced the VSS, Tach Sensor, the FIPL Sensor (and calibrated it), and replaced the fluid/filter. Yesterday at highway speeds the tranny slipped and my engine began revving. The tranny caught and the O/D light began flashing. The light continued flashing for about half an hour without anymore slipping. Every time I got off the highway the tranny was shifting erratically with the O/D light flashing.
I have a code reader, but have not been successful pulling the codes. The reader says it is not for 1994 vans, but I was told it worked for IDI's but not the PS engines. Can anyone provide any assistance? Thanks!
'94 E350, 7.3 IDI N/A, Propane Injection, 215K, "Short Bus"
<font color="red">Huskie Bus</font>
huskiemobileman is offline
Old 10-10-2006, 04:17 PM   #2 (permalink)
Re: E4OD Diagnosis
Make sure you have the accelerator to the floor the entire time you are pulling codes. the process is
1. Plug in reader (Leave turned off)
2. Turn key on (don't start)
3. Press and hold accelerator to the floor (or use a chicken stick propped up against the seat like I do)
4. Turn on code reader
5. hit test button
1993 Ford F-250HD XLT w/tow package (8,301 - 9,000# GVW) Single Cab, 7.3L IDI Non-turbo, 4x4, trac-lock 3.55 rear end, rebuilt E4OD with shift kit, ESE kit, and tranny cooler, ice-cold a/c, 245,000 miles.
http://www.geocities.com/aaron.m.joh...t/Truck_1.html
merdock69 is offline
Old 10-10-2006, 05:04 PM   #3 (permalink)
Re: E4OD Diagnosis
Slipping out of gear at highway speeds is indicitive of a mis-adjusted or defective MLPS (Manual Linkage Position Sensor) otherwise known as a neutral safety switch. (The switch tells the trans that it is in neutral at the wrong time).
It's a regular parts store part, if it has never been changed in the life of the van you will need to swap the connector housing which is included with the new sensor.
I used the Wal-Mart code reader on my 94 IDI van and it worked fine.
*ASE Master Certified, Medium & Heavy Trucks*
Mr_Roboto is offline
Old 10-10-2006, 07:00 PM   #4 (permalink)
Re: E4OD Diagnosis
Where is the connector for the reader? I am looking in the passenger compartment under the dash. I find a connector the looks correct, but it plugs into a buzzer that goes on when the door is open. I don't think that is it. The instruction manual says it is usually under the hood. Thanks for your input! [img]/ubbthreads/images/graemlins/cool.gif[/img]
Old 10-10-2006, 08:00 PM   #5 (permalink)
Re: E4OD Diagnosis
If you are in need of a E40d I have a freshly rebuilt one that I no longer need for a reasonable price.
Im no Einstein...but I might be a Rocket Scientist !
2001 F-350 2X4 Supercab longbed 7.3. 5" Bull Hauler stacks
1998 Dodge 2500 2X4 5.9 cummins racer
2006 Dodge 2500 4 Door 4X4 CTD
Lee Haenschen is offline
Old 10-10-2006, 09:11 PM   #6 (permalink)
Re: E4OD Diagnosis
Connector should be under the hood on the drivers' side, if I recall correctly.
Old 10-10-2006, 09:43 PM   #7 (permalink)
Re: E4OD Diagnosis
[/ QUOTE ]I will keep that in mind based on what I find out. Thanks for the offer.
Old 10-11-2006, 11:44 AM   #8 (permalink)
My Photos: (6)
Re: E4OD Diagnosis
Right. On my '92 the connector is under the hood, mounted on the fender near the hood spring on the driver's side. I think there are actually two connections required.
1992 F-350 Crew Cab ,7.3 IDI, 4x2, E4OD, Dually, white, pretty much stock, in California.
1986 F-250, 6.9 IDI, 4x4, C-6, Banks turbo, awaiting engine transplant, in Maine.
Gandalf is my truck. Gandalf is named after Gandalf in "The Lord of the Rings". He is the Wizard with mystical powers.
<font color="red"> My photos </font>
Gandalf is offline
Old 10-11-2006, 02:32 PM   #9 (permalink)
Re: E4OD Diagnosis
I agree, that's the problem.
Casey_1 is offline
Old 10-11-2006, 04:20 PM   #10 (permalink)
Re: E4OD Diagnosis
[/ QUOTE ]If I were to buy a new switch, would I need to adjust it like the FIPL Sensor (TPS)? Thanks.
Old 10-11-2006, 07:45 PM   #11 (permalink)
cdnsarguy's Avatar
My Photos: (66)
Re: E4OD Diagnosis
I do believe the later model have a fixed MLPS, once installed it is set using the cable and detents. I do know Okie gringo told me his was an adjustable and needed the C6 tool, but an older year truck........
Proud Canadian BOOB man too!!
cdnsarguy is online now
Old 10-11-2006, 10:28 PM   #12 (permalink)
Re: E4OD Diagnosis
Well I found the connectors for the scanner, but I can't get any codes out of the computer. The indicator on the scanner is telling me that it is hooked up to the computer, but it just shows 000 and doesn't change. I have followed all the directions and followed their troubleshooting. The only thing I didn't do was get the engine to operating temperature before getting the codes. I don't see why you would need to do this to retrive the codes.
Old 10-11-2006, 11:05 PM   #13 (permalink)
Re: E4OD Diagnosis
Check your fuses. I know on newer trucks the diagnostic port gets power from the same fuse as the cigarette lighter. I do not know if this applies to our trucks.
Old 10-12-2006, 08:43 AM   #14 (permalink)
Re: E4OD Diagnosis
Had the same problem, when and got a 24" rachet extension and propped it against the front seat to hold the accelerator down (Must be held down after turning key on and before turning tester on, and must be held down the entire length of the test). This did it for me.
Old 10-12-2006, 08:46 AM   #15 (permalink)
Re: E4OD Diagnosis
[/ QUOTE ]I held it down before turning ignition on. I will try holding it down after I turn the ignition on. Thanks for the info.
